Hello! I have recently upgraded from FreeNAS to TrueNAS Scale and am in the process of moving several containerized apps onto it using the native K8s service. I have installed Plex and the nginx Reverse Proxy Manager from the TrueNAS catalog. I added a second IP alias to the primary interface of the NAS and bound the cluster node to that IP while also assigning the TrueNAS UI to the first alias. DNS is provided from my pfsense (running its native unbound) and records for the custom hostnames exist and resolve correctly to the IP assigned to the k8s node. All containers start fine and the proxy UI works and will let me setup hosts without issue. However, when I attempt to access apps using the configured hostnames I get a connection refused error and a quick port check shows that TCCP 80/443 are not opened on the node IP. I don't think TrueNAS runs iptables/firewalld so I'm not entirely sure why I'm unable to connect. Using the first IP alias will allow the port to connect but the TrueNAS UI responds rather than the proxy. Moving the UI to an alternate port results in the same behavior. It's almost like the nginx deployment definition doesn't include a service that configures a clusterIP or load balancer. How do I get this proxy to answer externally from the node IP? Any advice would be greatly appreciated!
