dreamworks
- Nov 27, 2016
Hi guys,
SPEC:
Site 1: FreeNAS-9.2.1.7-RELEASE-x64
Site 2: FreeNAS-9.10.1-U4
I use the same linux client (CentOs) connecting to both FreeNas using the following fstab entries:
10.19.10.2:/mnt/vStoreEnc /data/backup nfs vers=3,async,rsize=524288,wsize=524288,timeo=14,noatime,nodiratime,intr
10.1.10.2:/mnt/vStoreEnc /data/backup.rz1 nfs vers=3,async,rsize=524288,wsize=524288,timeo=14,noatime,nodiratime,intr
As you notice I have rsize and wsize configured quite big.
When I now check /proc/self/mountstats on my linux client I get the following output:
device FreeNAS-9.2.1.7-RELEASE-x64:/mnt/vStoreEnc mounted on /data/backup with fstype nfs statvers=1.1
opts: rw,vers=3,rsize=65536,wsize=65536,namlen=255,acregmin=3,acregmax=60,acdirmin=30,acdirmax=60,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=10.19.10.2,mountvers=3,mountport=669,mountproto=udp,local_lock=none
device FreeNAS-9.10.1-U4:/mnt/vStoreEnc mounted on /data/backup.rz1 with fstype nfs statvers=1.1
opts: rw,vers=3,rsize=131072,wsize=131072,namlen=255,acregmin=3,acregmax=60,acdirmin=30,acdirmax=60,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=10.1.10.2,mountvers=3,mountport=965,mountproto=udp,local_lock=none
So the rsize and wsize settings are different between the FreeNas version. As I understand this seems to be a nfsd setting, but I neither a FreeBSD nor a FreeNas pro.
I wonder where and how I can set and increase them? I assume it's a tunable but which one? Where would I find more documentation on it?
Any hints would be appreciated...
SPEC:
