NFS unprivileged port
obeone
I cannot find how to allow connection from unprivileged port on NFS. I found someting about the option nfs_reserved_port_only in rc.conf but it's seem to not work on FreeNAS 8.2.
I need that for XBMC.
Any idea of how to enable that ?
Thank you
obeone
I found a dirty solution :
Modifying line mountd_flags in /etc/defaults/rc.local to add -n switch.
The line looks like after that :
mountd_flags="-nr" # Flags to mountd (if NFS server enabled).
But it might be better to have a checkbox in the web interface
obeone
Finally, bad solution...
This file is replaced on reboot, so we have to edit the file after each reboot.
Does anyone have a cleaner solution ?
obeone
Ho yes true, if it's not rw, it will not work.
I don't know why but my freenas crash on mount rw, but if I do quick, I can modify it before crash...
Thanks
