I am setting up my first FreeNAS setup, and trying to figure out the right way to setup datasets. Some are obvious - for storing family pictures, videos, etc. coming from Windows machines I'll want an SMB share.
The complicated question is what to do with datasets that I want accessible from both Windows and Linux. For example, I will have Plex running in a Docker container on a Linux box (separate hardware from the FreeNAS server), with the music itself stored on the NAS. The obvious way to access the datastore would be via NFS, but I want to be able to manipulate the files (add, move, etc.) from Windows machines. I can see several options, but not really sure which one would be best:
I have Win 10 pro on most machines, so can set up the Datastore to use NFS, and access it in Windows using the Windows NFS Services, though this seems clunky.
I can set the Datastore to use SMB, and access it from the Linux box via Samba, though again, this seems clunky.
Is there any way to set up a single datastore to be accessible through both SMB and NFS at the same time? This might be best, if possible. If it is, when creating the dataset, do I set the "Share Type" option to "Generic" or to "SMB"?
Thanks.
Thanks.
