NFS on 11.2-RELEASE can't add Active Directory Groups
rumbeard
So I've had AD groups in the drop-down and have been able to add them as a mapall group for many releases up to 11.1 U6. Upgraded and now it says the groups don't exist. First clue was the dreaded DOMAIN<Group> without the backslash showing up in a mountd error on the console. If I try to add them in the new GUI I see no AD groups. If I use the legacy GUI I see all the AD groups, but they say group does not exist upon save. I also came up with a blank /etc/exports upon upgrade. Changing one share re-populated everything, but again I get five group does not exist messages. Kind of lost on this one.
anodos
Sambassador
So I've had AD groups in the drop-down and have been able to add them as a mapall group for many releases up to 11.1 U6. Upgraded and now it says the groups don't exist. First clue was the dreaded DOMAIN<Group> without the backslash. If I try to add them in the new GUI I see no AD groups. If I use the legacy GUI I see all the AD groups, but they say group does not exist upon save. I also came up with a blank /etc/exports upon upgrade. Changing one share re-populated everything, but again I get five group does not exist messages. Kind of lost on this one.
Can you PM me a debug file?
rumbeard
Sure, how should I generate that?
Some extra info:
wbinfo -u and wbinfo -g work, and ls -l shows AD users and groups resolving. All SMB shares function correctly with Windows permissions/ACL.
anodos
Sambassador
Some extra info:
It sounds like an issue with the freenas-cache. You can try regenerating it under Directory Service -> Active Directory to see if it resolves your issue.
rumbeard
I tried this. Still no AD groups in new interface and present in old interface. Click save. Unknown group.
Message on console looks like this:
Domain is VALHALLA, dadm is group. Created nested due to spaces issue for Domain Admins
rumbeard
AD config
mikesm
I have a similar problem with 11.2. In the NFS sharing config, I can't set the mapall user to a windows domain user, and they don't show up in users or groups in accounts.
rumbeard
Rejoining the domain fixed this only for volume/dataset permissions, but still the same issue.
