NFS not showing snapshot rollback changes
hydrian
I recently started using snapshots for a versioned YUM repository. This
While testing one of my update scripts for my yum repositories, it accidentally deleted some of the directories I needed to keep. No problem. I had a snapshot of the previous version that I could easily rebase from.
The NFS Share is FREENAS1:mnt/VM_Vol1/GGVA-Yum-Repos/
So I rolled back the snapshot and checked in FreeNAS's file structure if it had done so. It looked like it had done it without issue.
root@FREENAS1:/mnt/VM_Vol1/GGVA-Yum-Repos/CURRENT # ls -l /mnt/VM_Vol1/GGVA-Yum-Repos/CURRENT
total 2
drwxr-xr-x  3 root  wheel   3 May 17  2019 epel
drwxrwxr-x  3 496   493     3 Nov 29  2018 extras
lrwxr-xr-x  1 root  wheel  25 Nov 11 13:03 os -> ../../CENTOS/7.6.1810/os/
drwxrwxr-x  3 496   493     3 Nov 29  2018 updates
My NFS mount is defined as:
/mnt/VM_Vol1/GGVA-Yum-Repos -alldirs -maproot="root":"wheel"
So I go check it on my NFS client where all the YUM update script runs from and the YUM HTTP repositories are hosted from. It is mounted as /mnt/GGVA-Yum-Repos on my CentOS 7 NFS client:
ls -l /mnt/GGVA-Yum-Repos/CURRENT/
total 1
drwxrwxr-x. 3 496 493 3 Sep 14 07:26 updates
I have it mounted as on the client:
freenas1.stc.int:/mnt/VM_Vol1/YUM_Repos on /mnt/data/yum_repos type nfs (rw,noatime,vers=3,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=10.1.1.226,mountvers=3,mountport=892,mountproto=udp,local_lock=none,addr=10.1.1.226)
At first, I thought this was a client caching issue, but it is not. I rebooted the client machine and the same issue there. I tried mounting the share from a new NFS client machine. I had the same issue.
Nothing not worthy is coming up in the client or server logs.
Does anybody have any idea at what I should throw at this thing?
What is your dataset structure?
An output of zfs list might help.
This also looks like a symbolic link to somewhere that is possibly outside your snapshot dataset... what did you restore the snapshot of? the whole Pool?
hydrian
It is a symlink to outside the dataset and it supposed to be that way. Once I have a snapshot made then I make a mount_nullfs mount from that dataset's .zfs/snapshot/(snap name) to the location in another NFS mount point. That's not the NFS mount I'm having an issue with.
hydrian
As you requested:
root@FREENAS1:~ # zfs list
NAME                                                       USED  AVAIL  REFER  MOUNTPOINT
SSD_Pool1                                                  305G   125G    23K  /mnt/SSD_Pool1
SSD_Pool1/Demo-GGVA60                                      102G   204G  22.8G  -
SSD_Pool1/Staging-GGVA62                                   102G   208G  18.9G  -
SSD_Pool1/Staging-GGVA63                                   102G   222G  4.42G  -
SSD_Pool1/iocage                                          3.62M   125G  3.48M  /mnt/SSD_Pool1/iocage
SSD_Pool1/iocage/download                                   23K   125G    23K  /mnt/SSD_Pool1/iocage/download
SSD_Pool1/iocage/images                                     23K   125G    23K  /mnt/SSD_Pool1/iocage/images
SSD_Pool1/iocage/jails                                      23K   125G    23K  /mnt/SSD_Pool1/iocage/jails
SSD_Pool1/iocage/log                                        23K   125G    23K  /mnt/SSD_Pool1/iocage/log
SSD_Pool1/iocage/releases                                   23K   125G    23K  /mnt/SSD_Pool1/iocage/releases
SSD_Pool1/iocage/templates                                  23K   125G    23K  /mnt/SSD_Pool1/iocage/templates
VM_Vol1                                                   1.17T   436G    96K  /mnt/VM_Vol1
VM_Vol1/.system                                            301M   436G   104K  legacy
VM_Vol1/.system/configs-e2eccb3703ad46d2b19f2e4809443384   129M   436G   128M  legacy
VM_Vol1/.system/cores                                     4.51M   436G  2.09M  legacy
VM_Vol1/.system/rrd-e2eccb3703ad46d2b19f2e4809443384       158M   436G  62.2M  legacy
VM_Vol1/.system/samba4                                    1.22M   436G   604K  legacy
VM_Vol1/.system/syslog-e2eccb3703ad46d2b19f2e4809443384   7.25M   436G  6.16M  legacy
VM_Vol1/.system/webui                                       88K   436G    88K  legacy
VM_Vol1/Buildbox7-Data1_2                                  136G   527G  44.7G  -
VM_Vol1/Demo-ArrayAG-2                                    80.8G   497G  19.4G  -
VM_Vol1/Demo-Gradiator2                                   81.3G   495G  22.3G  -
VM_Vol1/Demo-Lieberman                                    91.4G   498G  29.4G  -
VM_Vol1/Demo-NetScaler11                                  30.5G   453G  13.1G  -
VM_Vol1/Demo-Stinger                                      66.0G   487G  15.5G  -
VM_Vol1/Devel-Shrike                                      25.4G   448G  13.1G  -
VM_Vol1/Devel-jmeter2                                     81.3G   494G  22.9G  -
VM_Vol1/GGVA-Yum-Repos                                    87.3G   436G  5.34G  /mnt/VM_Vol1/GGVA-Yum-Repos
VM_Vol1/GGVA-Yum-Repos/CURRENT                            82.0G   436G  25.3G  /mnt/VM_Vol1/GGVA-Yum-Repos/CURRENT
VM_Vol1/ISOs                                               874M  99.1G   874M  /mnt/VM_Vol1/ISOs
VM_Vol1/Isolated_Client                                   30.5G   449G  17.7G  -
VM_Vol1/Linux-Admin                                       69.9G   486G  15.2G  -
VM_Vol1/Prime                                             96.0G   512G  18.3G  -
VM_Vol1/Prod-Thunderbolt                                   139G   563G  12.2G  -
VM_Vol1/Staging-PulseSecure                               50.8G   474G  12.3G  -
VM_Vol1/YUM_Repos                                         81.3G   119G  81.3G  /mnt/VM_Vol1/YUM_Repos
VM_Vol1/demo-PulseSecure92                                50.8G   473G  14.2G  -
freenas-boot                                              3.55G  24.1G    64K  none
freenas-boot/ROOT                                         3.53G  24.1G    29K  none
freenas-boot/ROOT/11.1-U7                                  344K  24.1G   741M  /
freenas-boot/ROOT/11.2-U7                                 2.28G  24.1G   760M  /
freenas-boot/ROOT/9.10.2-U6                               1.25G  24.1G   638M  /
freenas-boot/ROOT/Initial-Install                            1K  24.1G   635M  legacy
freenas-boot/ROOT/default                                  133K  24.1G   636M  legacy
freenas-boot/ROOT/default-20180702-233827                  328K  24.1G   838M  legacy
freenas-boot/grub                                         6.96M  24.1G  6.96M  legacy
hydrian
I'll try to explain the crazy system I have here.
I have mirrors of the Centos 7 major releases outside the dataset in question. These are downloaded once and don't change.
Then over the /mnt/VM_Vol1/GGVA-Yum-Repos NFS export I do the following things
  • I then create a symlink in /mnt/VM_Vol1/GGVA-Yum-Repos/CURRENT with the name 'os' in the version of CentOS I need work with,
  • Then I run a script that rsync mirrors the CentOS update, extra, and EPEL YUM repositories under the /mnt/VM_Vol1/GGVA-Yum-Repos/CURRENT dataset.
I then create VM_Vol1/GGVA-Yum-Repos/CURRENT snapshot. After that, I mount_nullfs the VM_Vol1/GGVA-Yum-Repos/CURRENT/.zfs/snapshot/{SNAP SHOT NAME} to /mnt/VM_Vol1/YUM_Repos/GGVA/{My Version Number}
My NFS client mounts to the /mnt/VM_Vol1/YUM_Repos/ and /mnt/VM_Vol1/GGVA-Yum-Repos NFS exports.
My issue is started when my script messed up my /mnt/VM_Vol1/GGVA-Yum-Repos/CURRENT directory. I rolled back to my most recent snapshot of VM_Vol1/GGVA-Yum-Repos/CURRENT. That's when the crap hit the fan. I checked the local files for that directory and they seemed fine. But if any machine looks at if via the NFS export, it looks like this:
[root@buildbox7 CURRENT]# ls -l
total 1
And not:
total 2
