Also just for the record to rule out any other non-network issue, Cifs capability was installed on the Freenas box and tried mounting the Freenas server with a Cifs share instead of a NFS share - Still the same problem:
Sep 23 04:44:40 myshare01 kernel: INFO: task php-fpm:2084 blocked for more than 120 seconds.
Sep 23 04:44:40 myshare01 kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Sep 23 04:44:40 myshare01 kernel: php-fpm D 0000000000000002 0 2084 2080 0x00000080
Sep 23 04:44:40 myshare01 kernel: ffff88020cb95ba8 0000000000000086 0000000000000000 ffffffff81fcf870
Sep 23 04:44:40 myshare01 kernel: 01ceb5ac78eb05bb 01ceaaa85fdefd00 01ceb12bd5e1242c 00000000000003e9
Sep 23 04:44:40 myshare01 kernel: ffff88020e0f7098 ffff88020cb95fd8 000000000000fb88 ffff88020e0f7098
Sep 23 04:44:40 myshare01 kernel: Call Trace:
Sep 23 04:44:40 myshare01 kernel: [<ffffffff812231f1>] ? avc_has_perm+0x71/0x90
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8150ed3e>] __mutex_lock_slowpath+0x13e/0x180
Sep 23 04:44:40 myshare01 kernel: [<ffffffff81224f94>] ? inode_has_perm+0x54/0xa0
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8150ebdb>] mutex_lock+0x2b/0x50
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8119037b>] do_lookup+0x11b/0x230
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8119069d>] __link_path_walk+0x20d/0x1030
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8119174a>] path_walk+0x6a/0xe0
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8119191b>] do_path_lookup+0x5b/0xa0
Sep 23 04:44:40 myshare01 kernel: [<ffffffff81182460>] ? get_empty_filp+0xa0/0x180
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8119285b>] do_filp_open+0xfb/0xdd0
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8109be2f>] ? hrtimer_try_to_cancel+0x3f/0xd0
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8103c7b8>] ? pvclock_clocksource_read+0x58/0xd0
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8119f562>] ? alloc_fd+0x92/0x160
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8117de79>] do_sys_open+0x69/0x140
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8117df90>] sys_open+0x20/0x30
Sep 23 04:44:40 myshare01 kernel: [<ffffffff8100b072>] system_call_fastpath+0x16/0x1b
Sep 23 04:45:42 myshare01 kernel: CIFS VFS: Server 10.95.1.40 has not responded in 300 seconds. Reconnecting...
Sep 23 04:45:42 myshare01 kernel: CIFS VFS: Send error in SETFSUnixInfo = -11
Sep 23 04:50:43 myshare01 kernel: CIFS VFS: Server 10.95.1.40 has not responded in 300 seconds. Reconnecting...
Sep 23 04:55:44 myshare01 kernel: CIFS VFS: Server 10.95.1.40 has not responded in 300 seconds. Reconnecting...
Sep 23 04:55:44 myshare01 kernel: CIFS VFS: Send error in SETFSUnixInfo = -11
Sep 23 05:00:45 myshare01 kernel: CIFS VFS: Server 10.95.1.40 has not responded in 300 seconds. Reconnecting...
Sep 23 05:00:45 myshare01 kernel: CIFS VFS: Send error in SETFSUnixInfo = -11
Sep 23 05:00:45 myshare01 kernel: CIFS VFS: Unexpected lookup error -5
Sep 23 05:05:47 myshare01 kernel: CIFS VFS: Server 10.95.1.40 has not responded in 300 seconds. Reconnecting...
Sep 23 05:05:47 myshare01 kernel: CIFS VFS: Send error in SETFSUnixInfo = -11
Sep 23 05:10:48 myshare01 kernel: CIFS VFS: Server 10.95.1.40 has not responded in 300 seconds. Reconnecting...
Sep 23 05:10:48 myshare01 kernel: CIFS VFS: Send error in SETFSUnixInfo = -11
Sep 23 05:10:48 myshare01 kernel: CIFS VFS: Unexpected lookup error -5
Sep 23 05:15:49 myshare01 kernel: CIFS VFS: Server 10.95.1.40 has not responded in 300 seconds. Reconnecting...
Sep 23 05:15:49 myshare01 kernel: CIFS VFS: Send error in SETFSUnixInfo = -11
Sep 23 05:20:50 myshare01 kernel: CIFS VFS: Server 10.95.1.40 has not responded in 300 seconds. Reconnecting...
Sep 23 05:20:50 myshare01 kernel: CIFS VFS: Send error in SETFSUnixInfo = -11
Sep 23 05:20:50 myshare01 kernel: CIFS VFS: Unexpected lookup error -5
Sep 23 05:25:51 myshare01 kernel: CIFS VFS: Server 10.95.1.40 has not responded in 300 seconds. Reconnecting...
Let me know if you have any success on the alpha if you install it (I might try it in the next couple days if time is willing) .
Also here is what mine network driver looks like:
[root@Storage00] /mnt/myvol00/mydir# sysctl dev | grep dev.em.0
dev.em.0.%desc: Intel(R) PRO/1000 Network Connection 7.3.7
dev.em.0.%driver: em
dev.em.0.%location: slot=0 function=0
dev.em.0.%pnpinfo: vendor=0x8086 device=0x1096 subvendor=0x8086 subdevice=0x3476 class=0x020000
dev.em.0.%parent: pci4
dev.em.0.nvm: -1
dev.em.0.debug: -1
dev.em.0.fc: 3
dev.em.0.rx_int_delay: 0
dev.em.0.tx_int_delay: 66
dev.em.0.rx_abs_int_delay: 66
dev.em.0.tx_abs_int_delay: 66
dev.em.0.itr: 488
dev.em.0.rx_processing_limit: 100
dev.em.0.eee_control: 1
dev.em.0.link_irq: 0
dev.em.0.mbuf_alloc_fail: 0
dev.em.0.cluster_alloc_fail: 0
dev.em.0.dropped: 0
dev.em.0.tx_dma_fail: 22118
dev.em.0.rx_overruns: 3
dev.em.0.watchdog_timeouts: 0
dev.em.0.device_control: 1075593793
dev.em.0.rx_control: 67141634
dev.em.0.fc_high_water: 30720
dev.em.0.fc_low_water: 29220
dev.em.0.queue0.txd_head: 213
dev.em.0.queue0.txd_tail: 215
dev.em.0.queue0.tx_irq: 0
dev.em.0.queue0.no_desc_avail: 0
dev.em.0.queue0.rxd_head: 955
dev.em.0.queue0.rxd_tail: 953
dev.em.0.queue0.rx_irq: 0
dev.em.0.mac_stats.excess_coll: 0
dev.em.0.mac_stats.single_coll: 0
dev.em.0.mac_stats.multiple_coll: 0
dev.em.0.mac_stats.late_coll: 0
dev.em.0.mac_stats.collision_count: 0
dev.em.0.mac_stats.symbol_errors: 0
dev.em.0.mac_stats.sequence_errors: 0
dev.em.0.mac_stats.defer_count: 0
dev.em.0.mac_stats.missed_packets: 361
dev.em.0.mac_stats.recv_no_buff: 128
dev.em.0.mac_stats.recv_undersize: 0
dev.em.0.mac_stats.recv_fragmented: 0
dev.em.0.mac_stats.recv_oversize: 0
dev.em.0.mac_stats.recv_jabber: 0
dev.em.0.mac_stats.recv_errs: 0
dev.em.0.mac_stats.crc_errs: 0
dev.em.0.mac_stats.alignment_errs: 0
dev.em.0.mac_stats.coll_ext_errs: 0
dev.em.0.mac_stats.xon_recvd: 0
dev.em.0.mac_stats.xon_txd: 0
dev.em.0.mac_stats.xoff_recvd: 0
dev.em.0.mac_stats.xoff_txd: 0
dev.em.0.mac_stats.total_pkts_recvd: 100075792
dev.em.0.mac_stats.good_pkts_recvd: 100075431
dev.em.0.mac_stats.bcast_pkts_recvd: 85022
dev.em.0.mac_stats.mcast_pkts_recvd: 553
dev.em.0.mac_stats.rx_frames_64: 131797
dev.em.0.mac_stats.rx_frames_65_127: 14411147
dev.em.0.mac_stats.rx_frames_128_255: 5080953
dev.em.0.mac_stats.rx_frames_256_511: 217218
dev.em.0.mac_stats.rx_frames_512_1023: 225632
dev.em.0.mac_stats.rx_frames_1024_1522: 80008684
dev.em.0.mac_stats.good_octets_recvd: 123487191509
dev.em.0.mac_stats.good_octets_txd: 60078821701
dev.em.0.mac_stats.total_pkts_txd: 128318863
dev.em.0.mac_stats.good_pkts_txd: 128318863
dev.em.0.mac_stats.bcast_pkts_txd: 3107
dev.em.0.mac_stats.mcast_pkts_txd: 14
dev.em.0.mac_stats.tx_frames_64: 37805
dev.em.0.mac_stats.tx_frames_65_127: 87150724
dev.em.0.mac_stats.tx_frames_128_255: 5437932
dev.em.0.mac_stats.tx_frames_256_511: 824081
dev.em.0.mac_stats.tx_frames_512_1023: 389396
dev.em.0.mac_stats.tx_frames_1024_1522: 34478925
dev.em.0.mac_stats.tso_txd: 10363597
dev.em.0.mac_stats.tso_ctx_fail: 0
dev.em.0.interrupts.asserts: 21175683
dev.em.0.interrupts.rx_pkt_timer: 4571
dev.em.0.interrupts.rx_abs_timer: 0
dev.em.0.interrupts.tx_pkt_timer: 269
dev.em.0.interrupts.tx_abs_timer: 519
dev.em.0.interrupts.tx_queue_empty: 0
dev.em.0.interrupts.tx_queue_min_thresh: 0
dev.em.0.interrupts.rx_desc_min_thresh: 0
dev.em.0.interrupts.rx_overrun: 0
I don't mind running slower than before as long as it runs :) is my driver out of date too? It looks a bit different from yours. Thanks!
dev.em.0.nvm: -1
dev.em.0.debug: -1
dev.em.0.fc: 3
dev.em.0.itr: 488
dev.em.0.dropped: 0
