essinghigh
- Feb 3, 2023
Hi All,
Running into a bit of a weird issue where my VM NFS clients are unable to cp a file to the TrueNAS NFS share until the command is run twice.
This also seems to cause issues with rsync, rclone, etc.
When the cp command is run for the first time, I get this "Operation not permitted" message, and a 0B file is created at /mnt/nfs.
The second time, the file is copied as expected. If I remove the 0B file and try again, I receive the "Operation not permitted" message again.
Not sure what is going on here, seems to be affected on multiple VMs.
My config on TrueNAS for the NFS share is as follows (I understand this might not be best practice from a security perspective, was just having a play about with NFS as had not set it up before).
Path: /mnt/data/SMB (Was previously an SMB share)
Both servers are authorized hosts
Read Only: Disabled
Mapall User: root
Mapall Group: root
The dataset is configured with NFSv4 permissions, as follows from when it was configured as an SMB share (this probably isn't the cause but want to add as much info as I can):
Group - Media | Allow, Full Access
User - libvirt-qemu | Allow, Full Access
User - Administrator | Allow, Full Access
User - root | Allow, Full Access
Owner & Group is root.
/etc/exports:
VM(s) /etc/fstab:
Where the clients can read (and eventually write) to the share I'm guessing it's not a permissions issue, so no idea what could be the cause.
Any pointers would be much appreciated, as can't seem to find anything relevant online with the exception of an IBM support page, which does not seem to be of any use....
Thanks in advance :)
root@isobuild:/media/torrents/complete# cp archlinux-2023.08.01-x86_64.iso /mnt/nfs cp: cannot create regular file '/mnt/nfs/archlinux-2023.08.01-x86_64.iso': Operation not permitted root@isobuild:/media/torrents/complete# cp archlinux-2023.08.01-x86_64.iso /mnt/nfs root@isobuild:/media/torrents/complete#
root@isobuild:/media/torrents/complete# cp archlinux-2023.08.01-x86_64.iso /mnt/nfs cp: cannot create regular file '/mnt/nfs/archlinux-2023.08.01-x86_64.iso': Operation not permitted root@isobuild:/media/torrents/complete# ls -la /mnt/nfs | grep arch -rwx------ 1 root root 0 May 27 1982 archlinux-2023.08.01-x86_64.iso root@isobuild:/media/torrents/complete#
root@isobuild:/media/torrents/complete# cp debian-12.1.0-amd64-netinst.iso /mnt/nfs cp: cannot create regular file '/mnt/nfs/debian-12.1.0-amd64-netinst.iso': Operation not permitted root@isobuild:/media/torrents/complete# rm /mnt/nfs/debian-12.1.0-amd64-netinst.iso root@isobuild:/media/torrents/complete# cp debian-12.1.0-amd64-netinst.iso /mnt/nfs cp: cannot create regular file '/mnt/nfs/debian-12.1.0-amd64-netinst.iso': Operation not permitted root@isobuild:/media/torrents/complete#
root@debian:~# dd if=/dev/urandom of=test.file bs=1 count=0 seek=1G 0+0 records in 0+0 records out 0 bytes copied, 4.1778e-05 s, 0.0 kB/s root@debian:~# cp test.file /mnt/nfs cp: cannot create regular file '/mnt/nfs/test.file': Operation not permitted root@debian:~# ls -la /mnt/nfs | grep test .rwx------ 0 root 30 Nov 2004 test.file root@debian:~# cp test.file /mnt/nfs root@debian:~# ls -la /mnt/nfs | grep test .rwx------ 1.1G root 2 Sep 21:51 test.file root@debian:~#
Read Only: Disabled
Mapall User: root
Mapall Group: root
/etc/exports:
"/mnt/data/SMB"\ 192.168.1.254(sec=sys,rw,anonuid=0,anongid=0,all_squash,insecure,no_subtree_check)\ 192.168.1.150(sec=sys,rw,anonuid=0,anongid=0,all_squash,insecure,no_subtree_check)\ 192.168.2.2(sec=sys,rw,anonuid=0,anongid=0,all_squash,insecure,no_subtree_check)\ 192.168.2.3(sec=sys,rw,anonuid=0,anongid=0,all_squash,insecure,no_subtree_check)\ 192.168.1.235(sec=sys,rw,anonuid=0,anongid=0,all_squash,insecure,no_subtree_check)
VM(s) /etc/fstab:
192.168.2.1:/mnt/data/SMB/ /mnt/nfs nfs sync,nolock,mountvers=3,nfsvers=3 0 0
