I am currently using the Nextcloud plugin.
I'd like to use a later/the latest version but I get this message...
I presume as a plugin thats not possible but also suspect if I reinstall as a jail (not plugin) the same limitation applies???
Am I stuck with using a VM if I want to use a later version (Not major issue but wanted to stay slim...)
Is there a FreeNAS roadmap to overcome this or is it simpler than I think?
Tim
You are running PHP 5.5. To allow you to upgrade to Nextcloud 11 and higher you need to run at least PHP 5.6. Once you upgraded your PHP version you will be able to receive update notifications for these newer versions.
Tim
