Hi
I successfully installed Freenas 11.2U and Nextcloud 17 on a VMWare ESXi but have ran into a major issue trying to get DDNS (No-IP) running with Nextcloud.
I can access Nextcloud locally on the RFC1918 IP but when I try to access it from the internet with either port 80 or 443, using DDNS (NO-IP), it just times out and I get no connection.
Actions undertaken:
1. Checked and verified that the DDNS url is online e.g. http://xxx.ddns.net
2. Configured the ddns url in the 'trusted domains' in the config.php file of the nextcloud jail.
3. Checked that the firewall is forwarding to the ddns url to the private IP (NAT) of the Nextcloud server.
4. Checked the log file but there's nothing in it, like it's not even getting a connection, even though I've double-checked the routing path from the firewall to the server and the /NAT/DDNS configuration which is fine. It's identical to another web server which is accessible from the internet on ddns.
I checked the documentation but cannot find any configuration examples nor detailed steps on setting up ddns for the Nextcloud jail.
Does anyone have an example configuration of the config.php file, as I suspect that something is wrong there or a step-by-step setup guide I could use from a working example?
I appreciate any help.
Thanks
Actions undertaken:
Thanks
