EvilLeprechaun
- Dec 12, 2014
I am looking to create my first NAS, and I'm stuck on step 1: the case. For me, noise is the primary concern (functionality is a given, and I care less about power consumption if more power will reduce the noise). The NAS is for home use, not for work.
I have a 19" 4-post open frame rack in my basement where the NAS will live, but the rack isn't behind any doors (unfortunate, but that's how it is). Right now the rack is just housing things like my router, a fanless switch, and an old PC sitting on a shelf, so noise hasn't been an issue thus far, and I'd like to keep it that way.
After reading the guides, things like ECC RAM seem like a no-brainer. I'd like to use 6 drives with RaidZ2, likely with 1- or 2-TB drives at first (because right now I care more about data protection than the amount of data being protected, and RaidZ2 gives better protection). I would love it if the drives could be hot-swappable, but that's not an absolute deal-breaker. My primary use for the server will be running CIFS for 2-3 concurrent users. Secondary uses will be backing up the files externally. If the server could transcode 1-2 simultaneous Plex streams, that would be fantastic, otherwise I'm open to making an HTPC dedicated to that task down the line.
I'm torn between going with a full 3/4U Supermicro case (from eBay, most likely) or going with a Mini ITX case. On the one hand, big case = big fans = quieter. That seems fairly straightforward. On the other, when I look up how to make a quiet rack-mounted server I see lots of people saying (effectively) "there's no such thing, rack-mounted servers are crazy-loud, get a tiny computer on a shelf if you want quiet."
These statements don't seem to agree (or maybe they do, and the "tiny computers" are just really underpowered). I imagine the excess noise in rack-mounted cases comes from niceties like big, redundant power supplies and the large number of fans required to cool lots of hot-swappable drives, but I'm just guessing. Does anyone have advice on which case I should start with? Thanks!
