D
Deleted member 108867
Guest
I have recently downloaded TrueNAS v12 to evaluate if it can replace my existing WHS2011 server. I started with a single 2tb hdd and have setup a pool with the single drive and 3 datasets with an open ACL. I have also created 4 users and given each user a unique to them folder under one of the datasets, so far all good. Now to my questions...........
1. I have added a second 2tb hdd to the pool, it has expanded the pool to approx. 3.7tb but I was expecting the second drive to mirror the first but it can't have done that as the pool has doubled in size.
2. In Windows10 I can see the shares and can create and delete items but I can not copy a directory into any dataset share without creating a folder first and then copying the files into the created folder. Once done I can copy folders into the newly created folder.
3. For some reason a couple of the user folders when viewed in Windows have some small files, they look like system files, in them which i presume TrueNAS put there as I didn't, why would that happen?
This is all very new to me and seems very complex.
Thanks
Thanks
