So I currently have 6 x 3TB drives, and 6 x 2TB drives. Half of these drives are for backups of data, so only half are really in use.
I would like to initially buy 2 x 4TB drives, and put them into a RAIDz2 with the 6 x 3TB existing drives (and then over time upgrade them to all 4TB drives).
My only issue is there is data on (3 of the 3TB drives) that I need. So would need to somehow copy it off somewhere. As I think ZFS would wipe the drives when they are put into the RAIDz2.
I've calculated I have about 12.7TB in use over the drives. So I could move (most) of this data onto the 6x2TB drives (and the remaining 0.7TB somewhere else, I'm sure I have another drive somewhere which could hold this).
Then I could put the new 2 x 4TB drives, and the old 6 x 3TB drives into the new FreeNAS system, and set up a RAIDz2. Which should give me 14.17TB of space (assuming only 3TB of each drive can be used), so I can copy the data back to the new RAID array.
So, my questions would be:
- How do I do this, is it a simple GUI on FreeNAS?
- How much work is it to change from the old 3TB drive(s) to new 4TB drive(s) (when I buy new drives to replace the old)?
- How much work is it to add additional drives to a RAIDz2 array after it's already been set up? For example, if I wanted to put in 2 more 4TB drives.
- What is the likelihood of a RAIDz2 failing? Do you guys have RAIDz2 or RAIDz3 (or mirrors/other)?
