BlueJ007
- Jun 25, 2018
I'm wanting to replace my Synology with FreeNAS, and I'm looking for configuration advice. The NAS has two primary uses: Plex media storage and VMware homelab; both over ISCSI. I have a separate system running Plex, so I don't need the NAS CPU to handle transcoding. The homelab has 10-20 VMs running: domain controller, SQL, vCenter appliance, Windows and Linux application servers. Currently, my Plex media needs 10TB and VMware about 1TB. Currently, my Synology and VMware host are directly connected via 10GB SFP+.
I'm thinking either a single RAIDZ2 vdev with 8 x 4TB drives or two RAIDZ2 vdevs with 4 x 4TB drives in a pool for media, and a separate pool for VMware, but I'm not sure if I should do mirrored, striped, or RAIDZ2 vdev. What would you all recommend? Also, should the VMware pool consist of HDDs or SSDs?
Hardware
Motherboard: Supermicro X11SSM-F
CPU: Xeon E3-1230v6
RAM: Crucial 16GB DDR-2133 CT16G4WFD8213 x 2
Boot SSD: Samsung 860 EVO 250GB
HBA: LSI 9211-8i
NIC: Intel X520-DA2
Thanks!
Hardware
CPU: Xeon E3-1230v6
HBA: LSI 9211-8i
NIC: Intel X520-DA2
Thanks!
