rockhead006
- Jul 11, 2018
Ok, so I'll go for the SAS card. Which would also allow me to have free SATA connections (on the motherboard) for the boot drive. I'll find a small SSD somewhere. What is the recommended size for FreeNAS. 32GB?
I'll also up my PSU from 450w to 650w. I don't foresee needing more than that. As I used a PSU calculator online and it came out at about 300w.
I'll go for the RAIDz2. With 8 drives in. So should give me 24TB of storage. I see the case I selected has room for 10 x 3.5" drives and 2 x 2.5" drives. So I'll have space to put in a couple of (my existing) 3TB drives in the other two 3.5" drive bays - which I'll use for a backup of critical files from the RAID. And put the boot SSD into one of the 2.5" bays.
I'm hoping the SAS card will fit in too.
So my planned system is:
CASE: Fractal Design Node 804 Case for Computer - Black
MOBO: Supermicro Micro ATX DDR4 LGA 1151 Motherboards X11SSM-F-O
CPU: Intel Pentium Dual-Core G4400 3.3 GHz Processor CPU
MEMORY: Kingston KTM-SX421/8G 8 GB DDR4-2133 MHz ECC Memory Module
HDDs: Seagate BarraCuda - 4 TB internal hard drive, Silver,ST4000DM004 x 8 (eventually)
PSU: Corsair CP-9020098-UK VS Series ATX/EPS 80 PLUS Power Supply Unit, 650 W
SAS CARD: 8x port SATA PCI-E SAS2008 HBA expansion hub LSI SAS 9211-8i IT mode M1015 #911
SAS CABLES: J&D Internal Mini SAS 36 Pin SFF-8087 to 4 SATA 7 Pin Forward Breakout Cable (50 cm) x 2
Am I missing anything? CPU cooler needed? Additional fans?
Total excluding HDDs is: £515 ($680). Hard drives for 8 would be £684 ($900).
My only problem is, I could afford the base system for now, and maybe a hard drive or 2. But not the whole 8 hard drives at once.
So how hard is it to add more HDDs in the future. I assume it requires a complete rebuild when adding each new drive. But is it easy/possible to do it?
Could I just put the new drive(s) in, add to the existing RAIDz2 array, and the array rebuilds and increases the available space. Or is it a lot harder than this?
Or could I use my existing 3TB drives, and add the new 4TB drives (obviously only able to use 3TB of the space), until they are all 4TB? Can I use the other 1TB (from the 4TB drives) somehow. E.g. in another array?
