Hi all and thanks for the awesome community.
I have old workstation that I would like to use as a home NAS/Virtualization.
My configuration is Lenovo E31 ThinkStation with Xeon E3-1225V2, 16 GB ECC RAM, 400 W PSU.
RAID Controller - 3ware 9650SE-8LPML
Hard drives - 8 various 1TB disks for the array and (probably) 120 GB SSD or 320 GB laptop disk for the OS.
I bought the RAID Controller with the idea to use it as RAID6 array, but now I've found the ZFS. The reason of RAID6 is the fault-tolerance (disks are not new and I expect in near future some faults).
The question is - should I create an RAID6 array or use the ZFS configuration? If ZFS then what configuration do you think would be good for me?
