New media NAS, disk problem
driver7
Good evening everyone, I'm having a bit of a problem with my new Freenas setup. I'm still waiting for the 6th hard disk to arrive and in the mean time I'm testing it out with the 5 I have in a RAIDZ1. Currently I haven't changed much in the settings other than starting CIFS, and setting up the CIFS shares. I transferred a recording (.wtv) from my media library on my old server over to the new Freenas and started watching it on a desktop machine using J River Media Center. Everything was fine until I started skipping around in the file, the video started to get a little jittery but recovers. When I checked the KVM console I've got the following error:
(ada2:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 00 4a 41 40 01 00 01 00 00
(ada2:ahcich3:0:0:0): Retrying command
and this repeats twice more.
The numbers change depending on where I am in the file, but it's always ADA2 that has the problem and this disk only had very little use before I noticed the error. I can easily recreate the error. I ran a short and a long smartctl test and they didn't detect any problems. Here is the output of smartctl:
[brandon@freenas] /# smartctl -a -q noserial /dev/ada2
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p10 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     HGST HDS724040ALE640
Firmware Version: MJAOA580
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    7200 rpm
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Sep 27 18:59:42 2014 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (   24) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off supp                  ort.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 583) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_                  FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -                         0
  2 Throughput_Performance  0x0005   136   136   054    Pre-fail  Offline      -                         81
  3 Spin_Up_Time            0x0007   131   131   024    Pre-fail  Always       -                         614 (Average 561)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -                         17
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -                         0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -                         0
  8 Seek_Time_Performance   0x0005   121   121   020    Pre-fail  Offline      -                         34
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -                         502
10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -                         0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -                         15
192 Power-Off_Retract_Count 0x0032   097   097   000    Old_age   Always       -                         3840
193 Load_Cycle_Count        0x0012   097   097   000    Old_age   Always       -                         3840
194 Temperature_Celsius     0x0002   176   176   000    Old_age   Always       -                         34 (Min/Max 21/39)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -                         0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -                         0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -                         0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -                         5
SMART Error Log Version: 1
ATA Error Count: 5
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 5 occurred at disk power-on lifetime: 463 hours (19 days + 7 hours)
  When the command that caused the error occurred, the device was active or idle                  .
  ER ST SC SN CL CH DH
  84 51 01 bf ff 4d 01  Error: ICRC, ABRT at LBA = 0x014dffbf = 21888959
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 40 e8 80 ff 4d 40 00      04:30:13.188  READ FPDMA QUEUED
  60 40 e8 00 ff 4d 40 00      04:30:13.188  READ FPDMA QUEUED
  60 40 e8 80 fe 4d 40 00      04:30:13.188  READ FPDMA QUEUED
  60 40 e8 c0 fe 4d 40 00      04:30:13.187  READ FPDMA QUEUED
  60 40 e8 40 fe 4d 40 00      04:30:13.187  READ FPDMA QUEUED
Error 4 occurred at disk power-on lifetime: 463 hours (19 days + 7 hours)
  84 51 d1 6f 9a 3e 01  Error: ICRC, ABRT at LBA = 0x013e9a6f = 20879983
  60 00 d0 70 9a 3e 41 ff      04:25:36.381  READ FPDMA QUEUED
  60 00 08 40 9b 3e 40 00      04:25:36.380  READ FPDMA QUEUED
  60 00 00 40 9a 3e 40 00      04:25:36.380  READ FPDMA QUEUED
  60 00 f8 40 99 3e 40 00      04:25:36.380  READ FPDMA QUEUED
  60 c0 f0 80 98 3e 40 00      04:25:36.379  READ FPDMA QUEUED
Error 3 occurred at disk power-on lifetime: 463 hours (19 days + 7 hours)
  84 51 d1 6f 43 fa 00  Error: ICRC, ABRT at LBA = 0x00fa436f = 16401263
  60 00 98 40 44 fa 40 00      03:51:45.041  READ FPDMA QUEUED
  60 00 90 40 43 fa 40 00      03:51:45.040  READ FPDMA QUEUED
  60 00 88 40 42 fa 40 00      03:51:45.040  READ FPDMA QUEUED
  60 00 80 40 41 fa 40 00      03:51:45.040  READ FPDMA QUEUED
  60 00 78 40 40 fa 40 00      03:51:45.040  READ FPDMA QUEUED
Error 2 occurred at disk power-on lifetime: 463 hours (19 days + 7 hours)
  84 51 41 7f f7 f2 00  Error: ICRC, ABRT at LBA = 0x00f2f77f = 15923071
  60 00 d8 c0 f7 f2 40 00      03:49:53.482  READ FPDMA QUEUED
  60 00 d0 c0 f6 f2 40 00      03:49:53.482  READ FPDMA QUEUED
  60 00 c8 c0 f5 f2 40 00      03:49:53.481  READ FPDMA QUEUED
  60 00 c0 c0 f4 f2 40 00      03:49:53.479  READ FPDMA QUEUED
  60 00 b8 c0 f3 f2 40 00      03:49:53.479  READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 5 hours (0 days + 5 hours)
  84 51 01 17 1b 57 00  Error: ICRC, ABRT at LBA = 0x00571b17 = 5708567
  60 80 00 17 1b 57 40 ff      05:41:29.059  READ FPDMA QUEUED
  60 80 e8 a0 1b 57 40 00      05:41:29.058  READ FPDMA QUEUED
  60 80 e0 98 1a 57 40 00      05:41:29.058  READ FPDMA QUEUED
  60 80 d8 90 19 57 40 00      05:41:29.058  READ FPDMA QUEUED
  60 80 d0 88 18 57 40 00      05:41:29.058  READ FPDMA QUEUED
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA                  _of_first_error
# 1  Extended offline    Completed without error       00%       473         -
# 2  Extended offline    Aborted by host               90%       464         -
# 3  Short offline       Completed without error       00%       464         -
# 4  Extended offline    Aborted by host               90%       464         -
Even more weird is if I watch the recording normally without skipping around it doesn't throw any errors at all. Any ideas?
EDIT: I tried reseating the cable but that didn't help.
EDIT2: Probably should have given some hardware/software info:
Machine is based on a Supermicro x10slm w/ Xeon 1230v3
16gb (4x4gb) Kingston ECC unbuffered memory, labeled KVR16E11S8/4. I recall that 3 of the sticks the chips that were branded as Kingston, and one of the sticks had chips that were branded Hynix.
Onboard Intel disk controller is used
Onboard NIC's are used
5x HGST Deskstar 4tb 7200rpm HD's
Sandisk 16gb USB drive for the OS
Machine doesn't have any expansion cards installed
The disk in question is NOT in a hotswap bay, 3/5 disks are in hotswap bays
All hardware is brand new
Running the latest Freenas 9.2.1.7
driver7
Trying a new sata cable, I don't know why I didn't think of it before. It's looking promising I'm skipping around the file without errors showing up on the console.
UDMA CRC errors are characteristic of bad SATA cables.
DrKK
FreeNAS Generalissimo
Concur. Everything about this situation smacks of a SATA cable/connection issue.
Yeah, it's very likely a cabling issue. Though don't rule out power as a possible cause. Power fluctuations due to poor cabling to the hard drive or something like an old or crappy PSU can cause this problem.
But, as a first step I'd replace the data cable. It's cheap, it's easy, and it fixes the problem about 90% of the time.
