Hi all,
Just got my new FreeNAS Mini XL+ today and loaded it with 8 6TB drives, mostly WD Red Pro.
While idling, the disk temperatures shot through the roof - several were in the 60 - 70C range.
Logging into the IPMI, it displays the speeds of the four fans. The default fan mode is "optimal", which gave a rear fan speed of 3100 rpm. Changing the mode to "HeavyIO speed" bumped that to 6000+ rpm and my drives started cooling down. There's also a full speed mode.
Make sure you change from optimal to HeavyIO or full - it's a bit noisier, but you won't melt your disks.
Best regards,
Mike
Best regards,
Mike
