Mynorx
- Aug 26, 2014
Just wanted to share my new build and give a little warning about booting from usb drives.
Build
As per forum recommended build guide I tried to follow as close as possible. found Here https://forums.freenas.org/index.php?resources/hardware-recommendations-guide.12/
1.super micro mobo
https://www.amazon.com/Supermicro-M...ro+ATX+Server+Motherboard+LGA+1151+Intel+C236
2. Intel Xeon E3-1220 V6 Kaby Lake 3.0 GHz
https://www.amazon.com/Intel-Xeon-E...words=Intel+Xeon+E3-1220+V6+Kaby+Lake+3.0+GHz
3. WD RED Hard drives x4
https://www.amazon.com/Red-3TB-Hard...r=1-3&keywords=WD+Red+3TB+NAS+Hard+Disk+Drive
4.APC 1500VA Compact UPS Battery Backup & Surge Protector
https://www.amazon.com/APC-Compact-...Watts+10+Outlets+Uninterruptible+Power+Supply
5. Seasonic FOCUS Plus Series SSR-650FX 650W 80+ Gold
https://www.amazon.com/Seasonic-SSR-650FX-ATX12V-Modular-Compact/dp/B073H33X7R/ref=sr_1_1?s=electronics&ie=UTF8&qid=1524509784&sr=1-1&keywords=Seasonic+FOCUS+Plus+Series+SSR-650FX+650W+80++Gold
6. SanDisk Ultra Fit 32GB USB 3.0 Flash Drive Mirror (CANNOT RECOMMEND)
The server was build for an electrical contractor. They have been in business for a couple of years but just got an office and are starting to network computers. So the system was running for about a week I went back to configure some settings and I see there is a problem with one of the Mirrored SanDisk usb boot drives
( Alert System - Critical The boot volume state is DEGRADED: One or more drives could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state). .
Not being and expert I researched and I figure out it was one of the mirrored usb drives I figured out how to properly remove the bad drive and decide to instead back up the configuration file and reinstall freenas on an SSD (good thing there was a best buy close by). Everything seems to be working fine now. There is a an error I noticed it after reinstalling freenas on the ssd it came up after I restored the configuration file (the configuration file was backed up and restored from the usb drive that was ok). error reads:
SYSTEM ALERT CRITICAL: The boot volume state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
Im using snapshots and synchronizing to a backblaze bucket. I think USB 3.0 drives get pretty hot and that is why it failed. If you insist on using usb boot drives I think you should be mirroring them but in reality should be booting off an SSD.
When I built the companies nas I decided to update mine. I was still runing v9.10. Version 11.4u is beautiful. I love the new features specially the cloud sync.
Build
1.super micro mobo
