Jon Telfer
- May 7, 2014
Hi All,
I've been getting odd email alerts through which I'd like your advice on. I get two emails - one "New Alerts" followed up a minute later with a "Gone Alerts" email. Sample alerts below :
and :
Machine is an HP Microserver with Intel(R) Celeron(R) CPU G1610T and 16gb ram. A few shares, Plex jail, Minecraft jail. Everything seems to work though...
Any thoughts welcome, Thanks,
Jon
New alerts:
* Unable to run alert source 'VolumeStatus'
File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute
return self.cursor.execute(sql, params)
File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute
execute = self.locked_retry(Database.Cursor.execute, query, params)
File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry
raise e
File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry
rv = method(self, *args, **kwargs)
sqlite3.OperationalError: database is locked
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/alert.py", line 358, in __run_source
alerts = (await alert_source.check()) or []
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/../alert/source/volume_status.py", line 15, in check
for pool in await self.middleware.call("pool.query"):
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1113, in call
return await self._call(name, serviceobj, methodobj, params, app=app, pipes=pipes, io_thread=True)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1049, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 664, in nf
File "/usr/local/lib/python3.6/site-packages/middlewared/service.py", line 266, in query
'datastore.query', self._config.datastore, [], datastore_options
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1063, in _call
return await run_method(methodobj, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1009, in run_in_thread
return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 175, in query
select=options.get('select'),
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 88, in __queryset_serialize
for i in qs:
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 256, in __iter__
self._fetch_all()
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 1087, in _fetch_all
self._result_cache = list(self.iterator())
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 54, in __iter__
results = compiler.execute_sql()
File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py", line 835, in execute_sql
File "/usr/local/lib/python3.6/site-packages/django/db/utils.py", line 94, in __exit__
six.reraise(dj_exc_type, dj_exc_value, traceback)
File "/usr/local/lib/python3.6/site-packages/django/utils/six.py", line 685, in reraise
raise value.with_traceback(tb)
raise e
django.db.utils.OperationalError: database is locked
Alerts:
raise e
for i in qs:
self._fetch_all()
raise e
django.db.utils.OperationalError: database is lockedand :
New alerts:
* Unable to run alert source 'Samba4'
raise e
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/../alert/source/samba4.py", line 11, in check
if not await self.middleware.call("datastore.query", "storage.volume"):
for i in qs:
self._fetch_all()
raise e
Alerts:
raise e
for i in qs:
self._fetch_all()
raise e
Jon
