Jon Telfer
- May 7, 2014
Hi All,
I've been getting odd email alerts through which I'd like your advice on. I get two emails - one "New Alerts" followed up a minute later with a "Gone Alerts" email. Sample alerts below :
and :
Machine is an HP Microserver with Intel(R) Celeron(R) CPU G1610T and 16gb ram. A few shares, Plex jail, Minecraft jail. Everything seems to work though...
Any thoughts welcome, Thanks,
Jon
New alerts: * Unable to run alert source 'VolumeStatus' Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) sqlite3.OperationalError: database is locked The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/alert.py", line 358, in __run_source alerts = (await alert_source.check()) or [] File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/../alert/source/volume_status.py", line 15, in check for pool in await self.middleware.call("pool.query"): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1113, in call return await self._call(name, serviceobj, methodobj, params, app=app, pipes=pipes, io_thread=True) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1049, in _call return await methodobj(*args) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 664, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/service.py", line 266, in query 'datastore.query', self._config.datastore, [], datastore_options File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1113, in call return await self._call(name, serviceobj, methodobj, params, app=app, pipes=pipes, io_thread=True) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1063, in _call return await run_method(methodobj, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1009, in run_in_thread return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 175, in query select=options.get('select'), File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 88, in __queryset_serialize for i in qs: File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 256, in __iter__ self._fetch_all() File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 1087, in _fetch_all self._result_cache = list(self.iterator()) File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 54, in __iter__ results = compiler.execute_sql() File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py", line 835, in execute_sql cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/utils.py", line 94, in __exit__ six.reraise(dj_exc_type, dj_exc_value, traceback) File "/usr/local/lib/python3.6/site-packages/django/utils/six.py", line 685, in reraise raise value.with_traceback(tb) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) django.db.utils.OperationalError: database is locked Alerts: * Unable to run alert source 'VolumeStatus' Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) sqlite3.OperationalError: database is locked The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/alert.py", line 358, in __run_source alerts = (await alert_source.check()) or [] File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/../alert/source/volume_status.py", line 15, in check for pool in await self.middleware.call("pool.query"): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1113, in call return await self._call(name, serviceobj, methodobj, params, app=app, pipes=pipes, io_thread=True) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1049, in _call return await methodobj(*args) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 664, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/service.py", line 266, in query 'datastore.query', self._config.datastore, [], datastore_options File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1113, in call return await self._call(name, serviceobj, methodobj, params, app=app, pipes=pipes, io_thread=True) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1063, in _call return await run_method(methodobj, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1009, in run_in_thread return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 175, in query select=options.get('select'), File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 88, in __queryset_serialize for i in qs: File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 256, in __iter__ self._fetch_all() File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 1087, in _fetch_all self._result_cache = list(self.iterator()) File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 54, in __iter__ results = compiler.execute_sql() File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py", line 835, in execute_sql cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/utils.py", line 94, in __exit__ six.reraise(dj_exc_type, dj_exc_value, traceback) File "/usr/local/lib/python3.6/site-packages/django/utils/six.py", line 685, in reraise raise value.with_traceback(tb) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) django.db.utils.OperationalError: database is locked
and :
New alerts: * Unable to run alert source 'Samba4' Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) sqlite3.OperationalError: database is locked The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/alert.py", line 358, in __run_source alerts = (await alert_source.check()) or [] File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/../alert/source/samba4.py", line 11, in check if not await self.middleware.call("datastore.query", "storage.volume"): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1113, in call return await self._call(name, serviceobj, methodobj, params, app=app, pipes=pipes, io_thread=True) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1063, in _call return await run_method(methodobj, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1009, in run_in_thread return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 175, in query select=options.get('select'), File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 88, in __queryset_serialize for i in qs: File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 256, in __iter__ self._fetch_all() File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 1087, in _fetch_all self._result_cache = list(self.iterator()) File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 54, in __iter__ results = compiler.execute_sql() File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py", line 835, in execute_sql cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/utils.py", line 94, in __exit__ six.reraise(dj_exc_type, dj_exc_value, traceback) File "/usr/local/lib/python3.6/site-packages/django/utils/six.py", line 685, in reraise raise value.with_traceback(tb) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) django.db.utils.OperationalError: database is locked Alerts: * Unable to run alert source 'Samba4' Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) sqlite3.OperationalError: database is locked The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/alert.py", line 358, in __run_source alerts = (await alert_source.check()) or [] File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/../alert/source/samba4.py", line 11, in check if not await self.middleware.call("datastore.query", "storage.volume"): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1113, in call return await self._call(name, serviceobj, methodobj, params, app=app, pipes=pipes, io_thread=True) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1063, in _call return await run_method(methodobj, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1009, in run_in_thread return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 175, in query select=options.get('select'), File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 88, in __queryset_serialize for i in qs: File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 256, in __iter__ self._fetch_all() File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 1087, in _fetch_all self._result_cache = list(self.iterator()) File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 54, in __iter__ results = compiler.execute_sql() File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py", line 835, in execute_sql cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/utils.py", line 94, in __exit__ six.reraise(dj_exc_type, dj_exc_value, traceback) File "/usr/local/lib/python3.6/site-packages/django/utils/six.py", line 685, in reraise raise value.with_traceback(tb) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) django.db.utils.OperationalError: database is locked
Jon
