Hey guys,
Have a weird issue here. I can see my server in windows network but when i click on it i get " The network path was not found " error.
I can however access my shares if i type in the IP address of the server instead.
what happens if you type the unc in the address block at the top of explorer? sounds like it may be a netbios naming/config issue. look in network>global config & maybe update name & save. then stop/start smb service. good luck.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
