SOLVED Network - replace switch with internal NIC & routing - howto?
flashdrive
regarding Rapid Spanning Tree Protocol:
How would this be setup? Using the TrueNAS console?
Patrick M. Hausen
From the ifconfig(8) manpage:
     stp interface
             Enable Spanning Tree protocol on interface.  The if_bridge(4)
             driver has support for the IEEE 802.1D Spanning Tree protocol
             (STP).  Spanning Tree is used to detect and remove loops in a
             network topology.
So you probably need to go to Network > Interfaces > bridge0 > Edit and then to the "Options" field. And for each of your physical interfaces, e.g. igb0, ix0, ix1 ... put this into your "Options" field:
stp igb0 stp ix0 stp ix1
Or similar. I have not used the feature so far.
flashdrive
got it, I have tried that setting out - I cannot see a difference
another hint:
I don't want to be disrespectul to the provided info, I am curious and have tried to keep this enabled
> disable hardware offloading in the physical interface settings for all member interfaces
for my system I could not see a negative impact with hardware offloading enabled. I am not running any VM / jails atm.
edit:
I stand corrected: enabling this will have a serious impact for my Windows client - browsing websites will become impossible.
keep the option disabled as has been suggested
Patrick M. Hausen
That only matters when you connect multiple switches and use multiple - possibly circular - links.
edit:
That's precisely why you need to disable it. Your PC is communicating via the bridge interface just the same as a jail/VM would.
HTH,
Patrick
