I'm curently builind a storage solution for home. I decided to try FreeNAS. After beeing able to install, setup and configure everything, I started to copy my file from temporary storage to my FreeNAS. Very surprised, I got poor copy performances. During the transfer, the copy seems to stuck on big files, loosing connection and have to restart/retry the copy. Windiws estimated speed fall from 110Mb/s to 0 and keep doing nothing and ..... error ..
I read on the forum to see that many user explain this issue by a Realteck OnBoard network adapter. ok ... I bought, with advise of many on this forum, an Intel network adapter (fully compatible as I can read)
And now, same issue :( Unable to copy file bigger than 1gig.
I tried to disable compression (maybe the NAs was unable to handle copy speed with compression...) Same issue...
Here is my setup, maybe you can help me solve this issue before changing the solution, maybe for a basic linux with cifs configured ...
FreeNAS-11.2-U5 (just upgraded... maybe)
Gigabyte/ GA-78LMT-USB3 R2 / AMD Fx6300
16 Gb RAM
OS: 1x Kingston A400 120GB SATA III
DATA: 3x WD WD30EZRZ RAIDZ
Intel Gigabit CT PCI-E Network Adapter EXPI9301CTBLK
Any ideas ?
Thanks for your help
16 Gb RAM
Any ideas ?
