Network interfaces diapering
tux-box1
morganL
Captain Morgan
Administrator
"forum Rules" apply here.
We need information on what version, when did it start happening?
Has anything changed?
tux-box1
My apologies.
TrueNAS-SCALE-22.02.0.1 "Angelfish"
2-May-22
Nothing's changed, I'm running through some thorough diagnostics now, they might take some time.
tux-box1
After a bit of digging, I believe I found the issue. Posting information here in case someone else will find it useful.
When I checked dmesg | Grep ixgbe i found a message along the lines of disabled due to unsupported device. I'm thinking ok? This worked before with truenas core, this is my fist run with scale and I didn't think it through that the driver code would be different.
I did some more digging: it seams Intel(R) Ethernet 10G 4P X520/I350 the nic in my r730xd has an on-device whitelist of SFP+ modules it will accept.
So I added a modprobe config, I'm not responsible for your copy pasting code!
echo "options ixgbe allow_unsupported_sfp=1" >> /etc/modprobe.d/ixgbe.conf
update-initramfs -u
I'm going to run some more tests soon, it's late, that's all for today.
tux-box1
Well the code I wrote in broke kuberneties it looks like, didn't even get around to testing other SFP+ modules. Re rolling the server fixed kuberneties, I'm back to my original problem. Looks it will be a fiber connection, Intel server side ubiquiti other side. I'll update after I get that done.
