milesnorth
- Dec 9, 2017
Spent last weekend building a Supermicro Atom C3558 freenas 11.0 box. So my sum total freebsd experience is an UEFI install to a flash drive on the front USB 2.0 port and 3 or 4 boots.
I have no ip for the web interface. I just pasted a bunch of my notes below. Any advise or pointing out an applicable help link would be greatly appreciated. Assume that I make basic mistakes.
If this is a hardware support problem I surmise that freenas 11.1 is required. Is installing this RC a bad idea? Is it difficult to transition to the stable release?
Best regards,
no freenas netwok interface notes:
dhcp sever sets freenas box ip as 10.0.0.50
freenas box post screen shows "bmc ip: 10.0.0.50"
freenas boot screen notes:
no ip for web interface at freenas console setup screen
in file /usr/local/etc/nginx/nginx.conf:
server_name localhost;
listen 0.0.0.0:80;
listen [::]:80;
Research:
https://forums.freenas.org/index.ph...s-not-to-be-detected-freenas-9-10-2-u6.59494/
https://forums.freenas.org/index.php?threads/intel-c3000-nic-hardware-support.59253/
build:
Supermicro A2SDi-4C-HLN4F Intel Atom C3558
Crucial CT16G4RFD4213 16GB Single DDR4 2133 MT/s CL15 DR x4 ECC Registered DIMM 288-Pin X 2
SanDisk Ultra Fit 32 GB USB 3.0 Flash Drive X 2
HGST 10TB Deskstar 7200 rpm SATA III 3.5" X 6
EVGA ATX 500W 80 Plus power supply
Fractal Design Dynamic 140mm White Case Fan X 3 (2 front, 1 rear)
Fractal Design Define R5 Titanium Case
CyberPower BRG1500AVRLCD Intelligent LCD UPS System, 1500VA/900W
Best regards,
pci6: <acpi pci bus> on pcib6 pci6: <network, ethernet> at device 0.0 (no driver attached) pci6: <network, ethernet> at device 0.1 (no driver attached) ... pci6: <acpi pci bus> on pcib7 pci6: <network, ethernet> at device 0.0 (no driver attached) pci6: <network, ethernet> at device 0.1 (no driver attached) ... pmc: unknown intel cpu ... etc/rc: warning: failed to start nginx
listen 0.0.0.0:80;
listen [::]:80;
Research:
build:
