Please describe your hardware.  This could be a configuration problem, a network problem, a memory problem, a power supply problem...
Intel s1200btl board with 16gb DDR ECC ram.  Intel Xeon E31275 CPU.  Has 2 IBM M1015 SAS cards.  Just installed Intel X520-DA1-10 Gbe-Single Port NIC.  After installing this random errors started.  Getting bunch of CPU Overheat errors and can't read state etc.  Was told to try Prerelease 11.1 and still get errors and when on RC3 get the NIC error stated before.  Just thinking rolling back to clean state wouldn't be back idea.  Also tried Nighties without much luck.
Also now after rolling back to U4 I can't update plugins.  I get this error now:
Request Method: POST
Request URL: http://10.0.1.100/plugins/plugin/update/1/
Software Version: FreeNAS-11.0-U4 (54848d13b)
Exception Type: MiddlewareError
Exception Value:
[MiddlewareError: b'There was a problem creating the PBI']
Exception Location: ./freenasUI/middleware/notifier.py in update_pbi, line 2548
Server time: Tue, 5 Dec 2017 08:11:25 -0700
Traceback
					Environment: Software Version: FreeNAS-11.0-U4 (54848d13b) Request Method: POST Request URL:
http://10.0.1.100/plugins/plugin/update/1/ Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 39.			 response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249.			 response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178.			 response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162.		 return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23.				 return view_func(request, *args, **kwargs) File "./freenasUI/plugins/views.py" in plugin_update 238.		 if notifier().update_pbi(plugin=iplugin): File "./freenasUI/middleware/notifier.py" in update_pbi 2548.			 raise MiddlewareError("There was a problem creating the PBI") Exception Type: MiddlewareError at /plugins/plugin/update/1/ Exception Value: [MiddlewareError: b'There was a problem creating the PBI']
Request information
GET
No GET data
POST
Variable Value
__form_id 'form_str'
FILES
No FILES data
COOKIES
Variable Value
fntreeSaveStateCookie 'root%2Croot%2F175%2Croot%2F176%2Croot%2F183'
csrftoken 'OPzRt38x7bAc1dBYPOiYxdXxKArDRx46C1tallSCDby3kZ28INNdvyTjoG3jp9oW'
sessionid 'zknsvamd3oqit3iukrbvbdtslnbxf31q'
META
Variable Value
