Hey guys,
Thought I would toss across my dilemma a bit.
I am getting very close to ordering parts, and I am trying to make a server for home use using the Xeon D platform in a Fractal Node 304. I am going to be making a second almost identical box to replace my ESXi server. Currently both boxes are just a frankenstein of parts. They have served me well but it is time to upgrade.
First, I believe I want to use the 6 core Xeon-D version, but I am thinking this might be overkill. I will be running Plex, about 7 other Jails, and I am hoping for 2-3 VM's on the new BHYVE interface. (Primarily a redundant AD Server and possibly an Ubuntu VM for crashplan).
https://www.superbiiz.com/desc.php?name=MB-X10D6C
(Sorry amazon and newegg does not have the correct part)
Alternatively I could go for a similar quad-core ASRock version:
https://www.newegg.com/Product/Product.aspx?Item=N82E16813599024
Unfortunately Supermicro does not make a D-1521 with the fan.
Now the issue is, I have read that I will pretty much NEED a modular power supply for the Node 304 case, because of how small it is. But I have done the calculations, and this build is going to be so low voltage that I am having difficulties finding a correct powersupply for this. I am thinking that:
https://www.amazon.com/dp/B008XEYT5M
Is going to be my best bet, even though 360W will probably be more than I will need. I was just curious if anyone out there knew something that I didnt.
Also just in case anyone is curious here is my current list:
Fractal Node 304 Case
X10SDV-6C+-TLN4F-O
6x WD Red 3TB (RaidZ2)
1x 500GB Samsung 860 Evo M.2 (For VMs and possibly Jails)
Seasonic 360W 80PLUS Gold
X10SDV-6C+-TLN4F-O
