Need help with permissions and groups
Nico
Hello world =)
I need som help on how groups work and how I set permissions. How I make groups and how I assign which permissions they have. So I can create ex. 2 groups with a user in each one.
And how to set the permission on storage so both groups can edit and write to the harddrive without using other.
Ex. If I make a folder in a harddrive and want one group to have full access to that folder alone, how do I do that?
Thanks for your help :)
Nico
ProtoSD
Lets say you you have 3 folders, one belongs to the first user & the group that user belongs to, another folder you want to be in common, and the third belongs to the second user & group.
The first folder and all of its files should be rwx------ (or chmod 700)
For the common folder:
you would need to add each user to the other users 'group'
and set permissions on each folder and file you want both users read/write access to rwxrwx--- (or chmod 770)
The third folder would be the same as the first, but owned by the other user.
This is just a quick overview, I'll try to update with some screenshots of the GUI in a bit.
Actually, I'll post the detailed answer in the HOWTO Thread.
