Need help with error!
Hello i've come across a issue after booting up FreeNAS (This also happened during installation) where it would come up with a Command Timeout Error, the attached image is what I get on screen! The system is rather dated to be honest but it does bootup the OS and the web panel is accessable.
System specs if it helps:
AMD Phenom 9650 Quad-Core
6GB DDR2
I did have FreeNAS running in a different system that was older which was running a Pentium D and 4GB DDR2
Thanks for any help!!!
nojohnny101
Please note you are running sub-par hardware and if you post about errors in the future, most likely you will get responses pointing out that your hardware doesn't mean minimum recommended specifications.
The minimum recommendations are there because any less can cause unpredictable and erratic behavior.
