Built my first FreeNas box a few weeks back, but I have yet to get to 100% working order. Here are some details of the machine:
Ver: 8.3.1-RELEASE (64bit)
CPU: Core 2 Duo 6400
Mobo: Gigabyte GA-965P-DS3 (latest bios is flashed)
RAM: 6GB (DDR2 6400)
HD: 3 1TB Seagate Barricuda drives in a RaidZ1 configuration
I have already replaced 2 brand new hard drives and 1 old one (a Western Digital green that was somewhat iffy going in, so I'm not counting that one), after getting this error on each one of them. Now I just got it again on a third brand new drive.
After that error pops, then I get a system warning:
"WARNING: The volume WynnMedia (ZFS) status is UNKNOWN: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'."
Replacing the hard drive with a brand new one fixes up the problem for a short while. Then when I start to copy a large amount of data over (roughly 20,000 files that take up 250GB), I get the above SMART error (drive number 2 simply disappeared, but also gave me the same error before disappearing from the pool). My file transfer hangs, and I have to figure out what happened and fix it.
Could I really be getting this many drive failures, or is this masking some other problem? I just want to figure out for sure what I need to replace so that I don't end back up at the store every day to return a bad hard drive. As I was typing this, this error just popped up in my log, not sure if it is causing this issue or not:
Thanks in advance for any help, I'm sure that posting some additional info would be helpful, just not sure exactly what would be useful to help out.
Apr 8 18:19:23 freenas smartd[2532]: Device: /dev/ada1, Failed SMART usage Attribute: 184 End-to-End_Error.
Apr 8 18:48:38 freenas kernel: MCA: CPU 0 COR L2 memory error
