Thanks for replay, the video did not resolve my problem ! i can't access to a folder password protected from my windows 8.1 ??? here are steps i made using only GUI :
STEP 1: Storage > ceate dataset
Dataset name : DATA
Compression level : Inherit (lz4)
Share type : windows
Case sensitivity : sensitive
Enable atime : Inherit (on)
ADD Dataset
Step 2: Add user ( advanced mode )
Username : Heinz (the same user on my windows 8.1 )
Create a new primary group for the user : Cheked
Create Directory in : /mnt/DreiTB/DATA
Home directory Mode owner : read / write / execute = Checked
Group : read / write / execute = UNchecked
Other : read / write / execute = UNchecked
Shell : sch
Full name : (my name)
Mail : ( my email)
Password : (the same password as my root for freenas)
Password confirmation (same pass )
Disable password login : UNCHECKED
Lock user UNCHECKED
Permit Sudo : Uncheckd
OK
Step 3 : Return to storage > Volumes > select DATA > Change Permissions
Apply Owner ( user) : checked
Owner ( user ) : Heinz
Apply Owner Group : checked
Owner Group : Heinz
Aplly Mode : Checked
Permission Type ! Windows
Set permission recursively Unchecked
Change
Sharing > Add Windows (CIFS )Share ( Advanced Mode )
Path : /mnt/DreiTB/DATA
Use as home share : UNchecked
Apply Deffault Permission : checked
Export read only : Unchecked
Browsable to Network : checked
Export Recycle bin : Uncheked
Show Hidden Files : Unchecked
Allow Guest Access : Unchecked
Only allow guest access : unchecked
Host allows : ( empty )
Host deney : ( empty )
OK
REBOOT FREENAS & MY PC
\\192.168.1.1.137 > i see tow folders ( MyNas ) is ok i can access without login
And the 2ed folder ( Private ) prompt for password but when i tape the password ( the same as the root for freenas )
I heve a message from windows
„ \\ 192.168.1.137 Private is not accessible .You can not be have the permissions required to use this network resource. Contact the administrator of this server to find out if you have the access permissions.
SEVERAL connections to a server or shared resource by the same user, using more than one user name, are not allowed. Disconnect all previous connections to the server or shared resource and try again. “
