- May 28, 2011
A RAIDZ2 of six 8TB drives gives you 29TB of available space = 23.2TB Usable space (subtracted 20% for the healthy pool rule) and this does not take into account compression.
16GB of RAM is absolutely fine for your use case.
And let me add this into the mix... If you are a handy person, you could purchase a different computer case and move the guts over to the new case, then if you need a few more SATA ports you just add a SATA add-on card. You may also be able to modify the original case but I think you would end up with a frankenstein looking thing unless you are a pro at metal work. And I'm not suggesting that the motherboard is a drop-in for any other case, you may need to do a little modification to mount it like drill a few holes. And you can get a PC case for as little as $30 delivered. I'm just putting this out there as I would honestly consider this for myself if all I wanted were a simple server doing what you desire and wanting that huge capacity.
You forgot to subtract the 20% which would give you 25.6TB Usable space.Essentially I want to run (8) x 6TB hard drive in a Raid z2 which would give me 36 gigs of usable space.
