jason.rohm
- May 7, 2013
Good evening.
I've once again backed myself into a technical corner and need help from those more expert than I to find my way out.
Today I attempted to do a BIOS/firmware upgrade on my LSI 9305-16i from the FreeNAS OS itself (9.10.1-U4). I started to do the BIOS upgrade and a kernel panic occurred. On reboot, the kernel panic reoccurs with similar output when importing the main volume.
I booted to DOS and did the firmware and BIOS upgrade again with no error. However, the system still craps out each time it boots. I attempted a FreeNAS "upgrade" over the top to ensure that there wasn't something wrong with the OS, but same result.
I plugged in a new boot media (USB thumb) and did a fresh install. I am able to mount the Volume but don't know what I need to do to get my dataset and iSCSI extent back. I'm afraid to just hammer away on it for fear of losing data. It wasn't clear to me if I could just create a new dataset and extent or if that would overwrite what is there.
This unit is backing my lab VMware environment and holds a ton of stuff that I really don't want to lose or have to recreate from scratch. I THINK the data is all there, there is just something farked up with the FreeNAS configuration, so I need to import/recreate in a nondestructive way.
Thanks all.
Thanks all.
