asajinx
- May 1, 2014
Thanks to all the information and suggestions on these forums i've came down to two possible decisions about my freenas box. #1. Build It (below)
CPU Intel Pentium G3220 3.0GHz Dual-Core
Any suggestions for the build or possible issues with it?
Advantages:
1. Case i picked offers me much better cooling of my 3.5 HD's
#2. Buy Lenovo TS140
Lenovo ThinkServer TS140
Advantages:
1. i3-4130 is far superior to the G3220 in performance and plex transcoding will work better. Not sure how much this really matters because i don't plan on using it for transcoding purposes (at the moment)
Both setups are going to roughly cost about the same. Thoughts/suggestions/comments?
$60.99
Case Fractal Design Define Mini MicroATX Mini Tower$89.99
Power Supply Corsair 430W ATX12V$39.99
Custom SUPERMICRO MBD-X10SLL-S-O uATX Server Motherboard$126.99
Kingston 8GB 240-Pin DDR3 SDRAM ECC Registered DDR3 1600 (PC3 12800) Server Memory$84.99
Advantages:
$319.99
Crucial 4GB 240-Pin DDR3 SDRAM ECC Registered DDR3 1600 (PC3 12800) Server Memory$55.99
Evercool 2x5.25 to 3x3.5 converter$25.00
Advantages:
