NAS won't boot anymore
OldDude
Today my system halted because it appears to have run out of memory... (subsequent searching through the forums here have shown me that I should be running the AMD64 version of software instead of the I386 that I am). When I attempted to restart the system the following gets displayed on my terminal:
F1 FreeBSD
F2 FreeBSD
F5 Drive 1
F6 PXE
Boot:   F1
error 32 lba 543951
No /boot/loader
FreeBSD/x86 Boot
Default: 0:ad(0,a)/boot/kernel/kernel
boot:
error 32 lba 543951
No /boot/kernel/kernel
FreeBSD/x86 Boot
boot:
The system has been running for almost 4 months now (aside from 2 prior restarts when the system "ran out" of memory), what happened?
Am I correct in assuming that FreeBSD now believes that my 16GB USB stick is only 512M in size?
What I need to know is what steps do I take to resolve this? NAS is a critical element of our manufacturing system.
Yes, I do have a configuration backup.
The software I'm using is FreeNAS 8.0-Release-I386
Any help is appreciated.
ProtoSD
  • Completely wipe your flash drive making sure there are no left over partitions.
  • Reflash it with the correct version of FreeNAS (amd64)
  • Boot it up, restore your settings, let it reboot, you should be back in business.
Edit: It probably wouldn't hurt to upgrade to version 8.02, lots of fixes..... (get 8.0 working first, then do the upgrade from CD after)
OldDude
Thanks for your quick reply!
We're up and running and back in business.
