PenalunWil
- Dec 30, 2013
To start I just thought I'd mention my play on words title to my build thread "my NASty box" where "ty" is Welsh for house, hence NAS house. Get it??? alright enough of the joking about...
Well I've decided to experiment with my Dell Optiplex 755 set up in UFS file mode with four 1TB HDD's and get a hands on learning curve to my first venture into FreeNAS before building my main NASty box. The drives will eventually be used in my main build which will be my first ever computer build comprising...
Case:- http://www.overclockers.co.uk/showproduct.php?prodid=CA-016-AE&tool=5
PSU:- http://www.overclockers.co.uk/showproduct.php?prodid=CA-164-CS&groupid=701&catid=123&subcat=2466
Mobo:- http://www.amazon.co.uk/ASRock-E3C2...cket/dp/B00G9TZHSQ/ref=pd_sim_sbs_computers_1
CPU:- http://www.ebuyer.com/467647-cpu-core-i5-4670k-3-40ghz-lga1150-box-bx80646i54670k
Cross Flashed SATA card: - http://www.redbooks.ibm.com/abstracts/tips0740.html
HDD's:- http://www.overclockers.co.uk/showproduct.php?prodid=HD-396-WD
HOUSED IN:- http://www.overclockers.co.uk/showproduct.php?prodid=HD-062-BT
RAM:- Obviously ECC and I'm starting with 2 x 4Gb (upgrade to full 16Gb later)
I may well change the Mobo to mATX with 32Gb RAM if I can find one with six SATA3 connectors
I can play around with the M1015 and the 6 SATA connectors to get the best setup.
I eventually plan to run eight HDDs but start with four. I'm not sure if you can add drives to the same pool as I go along so I may well have to backup and re-set the system.
It is WAY over the top for what I need but I think it's future proof. My main usage is for file transfer just for me and four devises 1 laptop, main desk top, and Galaxy pad, for my Architectural Business.
Comments would be gratefully appreciated.
Wil
Wil
