SuperVirtual
- Feb 1, 2015
I'm planning my first Freenas box. I'm stuck in the planning phase at this question. If running VirtualBox for Mythbuntu/Transmission from a PCI-E tv tuner ("tuner" )
Do I need particular hardware specs to do this? I read something about needing IOUMA? (can't find where I read it)
So far my build should be:
Would this board be sufficient for virtualbox + Plex + Owncloud + Crashplan et. al.
Am I going down the right route?
EDIT: Added PSU, Increased ram to 32GB
- Motherboard - Asrock C2750D4I Intel Mini ITX Motherboard
- Ram - 32 GB ECC RAM Size (Probably Crucial not sure)
- Hard Drives - 4TB * 6 WD Red Hard Drives RAIDZ2
- Addon Card - TV Tuner (above)
- Case - Fractal Design Mini
- PSU -Seasonic 460w FANLESS '80 Plus Platinum' Modular Power Supply
