Hi, I am preparing to setup my first FreeNAS server. It is going to be a KVM VM with an "IBM m1015 in IT-mode" passed through with pci-passthough.
Host is running on a asus x99-a motherboard with intel i7-5820k 6-core and 64GB ddr4 non-ecc ram.
I am planning on setting up a "raid z2" for the ability to loose an extra disk. the use for the raid will be a plex mediaserver with 5-6 users and an owncloud server with 5-6 users. will raid z2's performance be good enough for this type of usage?
The first issue I'm running in to is the fact that I dont have ECC ram, and right now money is tight, So it will most likly be a few months untill I can afford to do any upgrades. So the question here is, is the non-ECC RAM issue likely to break my ZFS system in the span of 2 months? the RAM I use now is about 6 months old, and memtest shows no issues.
As for my VM setup, I have enabled iommu for PCI-passthrough and I have used virt manager to set the VM up. I will paste the XML file under here, and if anyone sees any flaws in the setup I would be very, very grateful for a heads up. I would much rather feel like an idiot now, rather then 6 months from now :)
Everything seems to work fine, at least SMART seems to working on the disks connected to the m1015 controller.
XML Dump:
<domain type='kvm' id='5'>
<name>laden.local-Filserver-FreeNAS</name>
<uuid>6df8da78-104c-4a25-ba86-0155bdd2142d</uuid>
<memory unit='KiB'>17825792</memory>
<currentMemory unit='KiB'>17825792</currentMemory>
<vcpu placement='static'>6</vcpu>
<resource>
<partition>/machine</partition>
</resource>
<os>
<type arch='x86_64' machine='pc-q35-2.5'>hvm</type>
</os>
<features>
<acpi/>
<apic/>
</features>
<cpu mode='host-model'>
<model fallback='allow'/>
</cpu>
<clock offset='utc'>
<timer name='rtc' tickpolicy='catchup'/>
<timer name='pit' tickpolicy='delay'/>
<timer name='hpet' present='no'/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>restart</on_crash>
<pm>
<suspend-to-mem enabled='no'/>
<suspend-to-disk enabled='no'/>
</pm>
<devices>
<emulator>/usr/bin/kvm-spice</emulator>
<disk type='file' device='cdrom'>
<driver name='qemu' type='raw'/>
<backingStore/>
<target dev='sda' bus='sata'/>
<readonly/>
<boot order='1'/>
<alias name='sata0-0-0'/>
<address type='drive' controller='0' bus='0' target='0' unit='0'/>
</disk>
<disk type='file' device='disk'>
<driver name='qemu' type='qcow2'/>
<source file='/var/lib/libvirt/images/laden.local-Filserver-FreeNAS.qcow2'/>
<backingStore/>
<target dev='sdb' bus='sata'/>
<boot order='2'/>
<alias name='sata0-0-1'/>
<address type='drive' controller='0' bus='0' target='0' unit='1'/>
</disk>
<controller type='sata' index='0'>
<alias name='ide'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
</controller>
<controller type='pci' index='0' model='pcie-root'>
<alias name='pcie.0'/>
</controller>
<controller type='pci' index='1' model='dmi-to-pci-bridge'>
<model name='i82801b11-bridge'/>
<alias name='pci.1'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/>
</controller>
<controller type='pci' index='2' model='pci-bridge'>
<model name='pci-bridge'/>
<target chassisNr='2'/>
<alias name='pci.2'/>
<address type='pci' domain='0x0000' bus='0x01' slot='0x01' function='0x0'/>
</controller>
<controller type='virtio-serial' index='0'>
<alias name='virtio-serial0'/>
<address type='pci' domain='0x0000' bus='0x02' slot='0x02' function='0x0'/>
</controller>
<controller type='usb' index='0' model='nec-xhci'>
<alias name='usb'/>
<address type='pci' domain='0x0000' bus='0x02' slot='0x05' function='0x0'/>
</controller>
<serial type='pty'>
<source path='/dev/pts/15'/>
<target port='0'/>
<alias name='serial0'/>
</serial>
<console type='pty' tty='/dev/pts/15'>
<target type='serial' port='0'/>
</console>
<channel type='spicevmc'>
<target type='virtio' name='com.redhat.spice.0' state='disconnected'/>
<alias name='channel0'/>
<address type='virtio-serial' controller='0' bus='0' port='1'/>
</channel>
<input type='mouse' bus='ps2'/>
<input type='keyboard' bus='ps2'/>
<graphics type='vnc' port='5903' autoport='yes' listen='0.0.0.0'>
<listen type='address' address='0.0.0.0'/>
</graphics>
<sound model='ich6'>
<alias name='sound0'/>
<address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/>
</sound>
<video>
<model type='cirrus' vram='16384' heads='1'/>
<alias name='video0'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
</video>
<hostdev mode='subsystem' type='pci' managed='yes'>
<driver name='vfio'/>
<source>
<address domain='0x0000' bus='0x08' slot='0x00' function='0x1'/>
</source>
<alias name='hostdev0'/>
<address type='pci' domain='0x0000' bus='0x02' slot='0x03' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
</source>
<alias name='hostdev1'/>
<address type='pci' domain='0x0000' bus='0x02' slot='0x06' function='0x0'/>
</hostdev>
<redirdev bus='usb' type='spicevmc'>
<alias name='redir0'/>
</redirdev>
<alias name='redir1'/>
</redirdev>
<memballoon model='virtio'>
<alias name='balloon0'/>
<address type='pci' domain='0x0000' bus='0x02' slot='0x04' function='0x0'/>
</memballoon>
</devices>
<seclabel type='dynamic' model='apparmor' relabel='yes'>
<label>libvirt-6df8da78-104c-4a25-ba86-0155bdd2142d</label>
<imagelabel>libvirt-6df8da78-104c-4a25-ba86-0155bdd2142d</imagelabel>
</seclabel>
</domain>
