This has been a long time coming (I've been playing with the motherboard for over a year), but my FreeNAS build is finally complete!
SuperMicro A1SAi-2750F (8-core Atom)
Kingston KVR16LSE11/8 8G 1600MHz SODIMM (x4 for 32G)
Norco RPC-2008 2U Case
SeaSonic SS-400L2U 400W Gold Power Supply
USB drive for OS
WD Red 6TB (x6)
This system at idle pulls ~55W.
Writing at pretty much full gigabit speed using afp, it pulls ~63W
I plan on testing and learning more about FreeNAS/ZFS before I commit my data to it.
Currently, I have it running the latest 9.3 version and running RAIDZ2 for 23TB of space.
*** UPDATE ***
Out of curiosity, I swapped out the motherboard with a 2550 (4-core) version that is soon to be my router.
At idle, it pulled about 1 watt less than the 2750, and at full write load, it pulled about 2 watts less. At full write load, the CPUs were at about %50 utilization. Since the power difference was so small, I'm keeping the 8-core board in there for more room to grow.
- This is a fantastic low-power motherboard.
 - I am using the 6 onboard SATA ports for my pool.
 - It only has 2 USB2 ports, which makes installation interesting.
- I had keyboard and target drive connected, and installed from a SATA HDD that I dd'ed the image to.
 - I can't wait until FreeNAS supports USB3 again!
- It's ECC RAM... it works... not much to say about it!
- This case is pretty good for how cheap it is. The trays are a bit flimsy but it works.
 - The activity lights did not work with some of the 2.5" drives I tested with - the WD Reds work fine though.
 - The 4 fans that came with the case are very noisy so I replaced them with quieter ones (ARCTIC F8 PWM PST).
- The new fans have 4-pin connectors so I couldn't use the nice 3-pin connection mechanism that is built into the case's fan mounts.
- I really wanted a Platinum PS but couldn't find any available in a 2U form factor.
- the ones I found were OEM only so I couldn't get just one - i did submit it to newegg though.
USB drive for OS
- Nothing fancy here.
WD Red 6TB (x6)
- I was planning on 4TB drives but decided to go bigger at the last minute.
*** UPDATE ***
