My case has a lot of extra power connections coming out of the power supply.
In the motherboard compartment, there are one 24 pin, two 8-pin, and one 4-pin. I'm only using the 24-pin and one of the 8-pin, both attached to my x11ssh-f motherboard. Do I need to attach the other ones somewhere? What are they used for?
In the backplane compartment, there are three "stalks" of wires, where each "stalk" has 4-pin linear bigger, to connected to a 4-pin linear bigger, connected to a small 4-pin one. I have the backplane connected to two of the big 4-pin ones from the same "stalk". Is this correct? What is the use for all the other connections?
My e3-1230 v6 came with a heat sink fan, which has some grease on the place where cpu touches. Do I need thermal paste? Intel manual doesn't mention it.
My chassis came with two i-spgio cables. Do I use both of them to connect backplane to motherboard? How do I know the correct orientation?
Thanks!
Thanks!
