pious_greek
- Nov 28, 2017
The SuperMicro Superchassis CSE-505-203B 1U rack mount, includes a 200w PSU. The supermicro website lists compatible motherboards, and the X10SDV-TLN4F-O is listed on there as compatible.
BUT the 200w PSU in the rack mount has a 20 pin atx, while the X10SDV motherboard accepts a 24 pin ATX.
I have a 20 pin PSU to 24 pin motherboard adapter, but the 1U rack is very tight on space and i would prefer to avoid the adapter.
Given SuperMicro lists the board as compatible with the rack, can I safely operate the X10SDV off a 20 pin atx?
thank you
thank you
HARDWARE SuperMicro Superchassis CSE-505-203B 1U rack mount, 200w PSU X10SDV-4C+-TLN4F-O Crucial 32GB Kit (16GBx2) DDR4-2133 MT/S (PC4-17000) CL15 dual ranked x4based ECC Registered Server Memory CT2K16G4RFD4213 INTEL I350T4V2BLK Gigabit Ethernet Network Server Adapter I350-T4 V2 Quad Ports OR Chelsio T520-BT, dual port 10GBase-T 10 Gigabit Ethernet Unified Wire adapter with PCI Express 3.0 Additional Parts Supermicro FAN-0100L4 40X40X28MM 1U-4-Pin PWM Fan SC510 SC511 Supermicro MCP-320-81302-0B Single fan holder for one 40x28mm fan Supermicro MCP-120-00063-0N Riser card bracket for slot-7 in SC504 Supermicro Riser Card RSC-RR1U-E16 Supermicro MCP-260-00100-0B 1U I/O Shield for X10SDV-7TP8F in SC510/SC505/SC504 9 Pin Motherboard Female Header to 2 Port Dual USB 2.0 Female Adapter Cable 2X SanDisk Ultra Fit 16GB USB 3.0 Flash Drive SDCZ43-016G-G46
