topsub
- Feb 18, 2012
Hey Guys,
I figured i would post my build log ( will add pictures ) of my build. This is my first time building a freenas box and wanted to try and document it. I want to build this and use it as a media streaming along with data storage for some of my work. I just wired my house with cat 6 and a dell 2412 web managed switch to prepare for this nas system. I dropped at least 1 wire in each room along with 8 in my loft ( office ). Some external devices i have include a OBI100 and HDHomerun for over the air signal. my HTPC Part list are below, The 'Full HTPC' does the lets say processing of the tv shows and movies and the 'Mini HTPC' is just a streamer. I also have a WRT Router for wireless. I think i finally found an 'N' supported wifi card that i can buy to put inside the m0n0wall router.
Here is the part list:
30TB FreeNas Box:
1x LSI Internal SATA/SAS 9211-4i 6Gb/s PCI-Express 2.0 RAID Controller Card, Single
1x Antec EarthWatts EA-500D Green 500W ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply
1x ASUS F1A75-M FM1 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 HDMI Micro ATX AMD Motherboard with UEFI BIOS
1x AMD A4-3300 Llano 2.5GHz Socket FM1 65W Dual-Core Desktop APU with DirectX 11 Graphic AMD Radeon HD 6410D AD3300OJGXBOX
1x Intel E1G44HTBLK 10/ 100/ 1000Mbps PCI-Express 2.0 Server Adapter I340-T4
4x G.SKILL Ripjaws X Series 8GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9S-8GBXL
1x StarTech.com SAS8087S450 50cm Serial Attached SCSI SAS Cable - SFF-8087 to 4x Latching SATA
1x Icy Dock MB455SPF-B 5 in 3 SATA I / II & III Hot-Swap Internal Backplane Raid Cage Module
10x Barracuda 7200RPM 3 TB SATA 6 GB/s NCQ 64 MB Cache 3.5-Inch Internal Bare Drive - ST3000DM001
6x OKGEAR 18" SATA 6 Gbps Cable, Straight to Left Angle W/ Metal Latch, Black, Backward Compatible 3 Gbps and 1.5 Gbps
1x 3U 3x5.25" + 5 x 3.5" Bays Rack Mount Chassis
M0n0Wall Router:
1x Athena Power RM-1U102ITX25 Black 1.2mm Steel 1U Compact Workstation/Server Mini ITX Chassis
1x PCI Riser Card Adapter 32Bit for 1U Units
1x Intel BOXD525MW Intel Atom D525@ 1.8GHz (Dual Core) BGA559 Intel NM10 Mini ITX Motherboard/CPU Combo
1x G.SKILL 4GB (2 x 2GB) 204-Pin DDR3 SO-DIMM DDR3 1333 (PC3 10666) Dual Channel Kit Laptop Memory Model F3-10666CL9D-4GBSQ
1x Intel PWLA8391GTL 10/ 100/ 1000Mbps PCI Desktop Adapter PRO/1000 GT Low Profile - OEM
1x Patriot Xporter XT Boost 8GB Flash Drive (USB 2.0 Portable) Model PEF8GUSB
Full HTPC: ( Runs 55inch Series 8 Samsung LED TV )
1x LIAN LI Black Aluminum PC-C33B ATX Media Center / HTPC Case
1x GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
1x SeaSonic M12II 520 Bronze 520W ATX12V v2.3 / EPS 12V v2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
1x AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
1x ADATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333G (PC3 10666) Desktop Memory Model AX3U1333GB2G8-2G
1x Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
1x Logitech diNovo Edge 2-Tone Bluetooth Wireless Mini Keyboard
1x Scythe Big Shuriken SCBSK-1000 120mm CPU Cooler
2x Noctua NF-R8-1800 80mm Case Fan
1x AZiO BTD-V201 Micro Bluetooth Adapter USB 2.0
1x Arctic Silver 5 Thermal Compound - OEM
1x Noctua NF-P14 FLX 140mm Case Fan
1x Logitech MX Air Silver/Black 8 Buttons 2.4 GHz Cordless Laser Rechargeable Air Mouse
1x LITE-ON Black 4X Blu-ray Disc Reader SATA Model iHOS104-08
2x Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 996770
Mini HTPC: ( Runs 46inch Series 7 Samsung LED TV )
1x Zotac ZBOX-ID36BR3D-PLUS Intel Atom D525 CPU 1.8 GHz Dual-Core Next-generation NVIDIA ION w/2GB RAM, 250G HDD Blu-ray All-in-One Mini-PC
1x Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
1x Logitech diNovo Mini Black Bluetooth Wireless Mini Keyboard
Old Nas Parts ( bought thinking i would use this with 18TB then upgraded before i even built it):
1x PNY Optima 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model MD8192KD3-1333
1x StarTech USBMBADAPT 6in USB 2.0 Cable - USB A Female to USB Motherboard 4 Pin Header F/F
1x Antec EarthWatts Green EA-380D Green 380W Continuous power ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply
1x ASUS E35M1-I Fusion AMD E-350 APU (1.6GHz, Dual-Core) AMD Hudson M1 Mini ITX Motherboard/CPU Combo
I will be gathering pictures if you guys want to see. I will / hopefully collecting the rest of my NAS and mini HTPC this week.
Thanks for stopping by!
30TB FreeNas Box:
M0n0Wall Router:
