eccevery
 - Oct 24, 2014
So the time has come for my 2nd FreeNAS build. This will be a small, but serious, NAS build for backup at home. Priority is quality, performance and low noise. No jails. I will also give FreeNAS 10 a try. It will have VERY low usage, but if you going to do something, do it properly! What do you guys think about this setup?
Supermicro X10SDV-2C-TLN2
Kingston Kingston ValueRAM DDR4 PC17000/2133MHz ECC Reg CL15 16GB (KVR21R15S4/16)
4x WD Red WD30EFRX 64MB 3TB
Noctua NF-A6x25
Fractal Design Node 304
Be Quiet! System Power 8 400W
Kingston SSDNow M.2 G2 SM2280S3G2 120GB
I can think of three questions you might have right away:
- Why not boot from a USB stick? Well... mainly because I cannot find a USB port directly on the motherboard. ;)
- The Noctua 60mm fan goes directly on the CPU heatsink. I know mount points aren't there, but I'll figure something out.
- The case: I like it. It lets me choose the PSU (noise is a priority, remember?). No hot swap disk bays, but it's not needed.
I'm not terribly found of 10Gbps RJ45, an SFP+ slot would be a lot better, but the cheap devil won that round.
Any comments or thoughts before I order a bunch of stuff and then can't sleep before it all arrive?
Noctua NF-A6x25
