Hello guys,
My goal for my FreeNAS server is strictly for home use and "as a hobby". I want to use it for storage (duh), Plex, maybe a few VM's and whatever plugin I may find at a later point that tickles my interest. If I get it up and running, I will likely share it between some family and friends. This would put me at the "medium" requirements (I'm guessing) and have made my list based on the various guides I found while researching FreeNAS. Though I do want it all to 'work', I'm expecting the data that will be stored on this server to be non-critical, so its not a major priority if I lose it.
The list so far:
Fractal Design Node 804
SuperMicro X11SSM-F
Intel Core i3 6300 Boxed
Samsung D4 16GB(1x16GB) 2133MHz, CL15
3 x WD Red 3 TB
Seasonic G-Series 450W
Corsair Flash USB 3.0 16GB Slider X2 (maybe two so i can use one as a backup for FreeNAS itself)
I will gladly listen to suggestions for my build and improvements. If some of these parts are overkill, please let me know.
Thank you in advance.
The list so far:
SuperMicro X11SSM-F
3 x WD Red 3 TB
