Wallybanger
- Apr 17, 2016
Hey Guys,
I have a bunch of files (600gb worth) that need to be moved between shares and if I do it via windows it transfers the files across the network. I figured the way around this would be to move with the CLI.
So dialed down into my main Dev directory and entered this:
The CLI then started pumping out error messages. The files are being copied from the source to the target but not moved and it's going rather slower than I expected.
Should I be using the FULL path with the mv command?
Also, why is the /bincp Shared/ directory coming up? Is that just because that's where the mv binary is located?
The user I logged into the shell with has full read/write access to both shares so I'm not sure why I would be getting chmod errors..... does it have something to do with a UNIX/ACL permission clash?
Primo@Nassy:/mnt/DirtyData % mv Shared/Wally/Desktop\ File\ Recovery/movies/*.* Movies/New\ -\ Unsorted/
mv: chmod: Movies/New - Unsorted/2.Guns.2013.720p.BluRay.x264-SPARKS [PublicHD]/2.guns.2013.720p.bluray.x264-sparks.nfo: Operation not permitted mv: chmod: Movies/New - Unsorted/2.Guns.2013.720p.BluRay.x264-SPARKS [PublicHD]/Downloaded From PublicHD.SE.txt: Operation not permitted mv: chmod: Movies/New - Unsorted/2.Guns.2013.720p.BluRay.x264-SPARKS [PublicHD]/2.guns.2013.720p.bluray.x264-sparks.mkv: Operation not permitted mv: chmod: Movies/New - Unsorted/2.Guns.2013.720p.BluRay.x264-SPARKS [PublicHD]: Operation not permitted mv: /bin/cp Shared/Wally/Desktop File Recovery/movies/2.Guns.2013.720p.BluRay.x264-SPARKS [PublicHD] Movies/New - Unsorted/2.Guns.2013.720p.BluRay.x264-SPARKS [PublicHD]: terminated with 1 (non-zero) status
