jeberhardt
 - Feb 3, 2020
my name is Jürgen and I am quite new to FreeNAS. I'm using FreeNAS-11.3-RELEASE
My network setup looks like this:
bridge0 with member lagg0 --> internal net
bridge1 with member lagg1 --> DMZ net
I have the following problems with vnet in jails and couldn't find help in the documentation and the web:
1. MAC addresses are no longer automatically generated
2. Other vnet beside vnet0 are not generated and/or working
3. I can't create two or more interfaces. As soon as I select the IPv4 interface from the drop down menu in the jail settings nothing works anymore. The command iocage -D start nextcloud shows me the following:
As soon as I remove the selection of IPv4 interfaces the jail works again but only with one address. What I want to do is to give the nextcloud server two interfaces to connect to the mysql server in another subnet. Existing jails work without problems even after restarting the jail or FreeNAS.
Here is the config for the jail:
Best regards
Jürgen
Grabbing IPv4 default route
Default IPv4 Gateway: 10.0.0.1
Grabbing IPv6 default route
No default gateway found for ipv6.
Default IPv6 Gateway: none
* Starting nextcloud
ioc-nextcloud: run command: /sbin/mount -t devfs -oruleset=6 . /mnt/share/iocage/jails/nextcloud/root/dev
ioc-nextcloud: run command: /sbin/mount -t fdescfs . /mnt/share/iocage/jails/nextcloud/root/dev/fd
ioc-nextcloud: run command: /usr/bin/true
ioc-nextcloud: jail_set(JAIL_CREATE) name=ioc-nextcloud vnet=new allow.set_hostname=true sysvmsg=new sysvsem=new sysvshm=new host.domainname=none host.hostname=nextcloud path=/mnt/share/iocage/jails/nextcloud/root securelevel=2 host.hostuuid=nextcloud devfs_ruleset=6 enforce_statfs=2 children.max=0 persist
ioc-nextcloud: created
  + Started OK
  + Using devfs_ruleset: 6
Setting default route 10.0.0.1
  + Configuring VNET FAILED
  route: writing to routing socket: Network is unreachable
add net default: gateway 10.0.0.1 fib 0: Network is unreachable
ioc-nextcloud: removed
ioc-nextcloud: run command: /sbin/umount /mnt/share/iocage/jails/nextcloud/root/dev/fd
Stopped nextcloud due to VNET failureAs soon as I remove the selection of IPv4 interfaces the jail works again but only with one address. What I want to do is to give the nextcloud server two interfaces to connect to the mysql server in another subnet. Existing jails work without problems even after restarting the jail or FreeNAS.
CONFIG_VERSION:26
allow_chflags:0
allow_mlock:0
allow_mount:0
allow_mount_devfs:0
allow_mount_fusefs:0
allow_mount_nullfs:0
allow_mount_procfs:0
allow_mount_tmpfs:0
allow_mount_zfs:0
allow_quotas:0
allow_raw_sockets:0
allow_set_hostname:1
allow_socket_af:0
allow_sysvipc:0
allow_tun:0
allow_vmm:0
assign_localhost:0
available:readonly
basejail:0
boot:0
bpf:1
children_max:0
cloned_release:11.3-RELEASE
comment:none
compression:lz4
compressratio:readonly
coredumpsize:off
count:1
cpuset:off
cputime:off
datasize:off
dedup:off
defaultrouter:auto
defaultrouter6:auto
depends:none
devfs_ruleset:4
dhcp:0
enforce_statfs:2
exec_clean:1
exec_created:/usr/bin/true
exec_fib:0
exec_jail_user:root
exec_poststart:/usr/bin/true
exec_poststop:/usr/bin/true
exec_prestart:/usr/bin/true
exec_prestop:/usr/bin/true
exec_start:/bin/sh /etc/rc
exec_stop:/bin/sh /etc/rc.shutdown
exec_system_jail_user:0
exec_system_user:root
exec_timeout:60
host_domainname:none
host_hostname:nextcloud
host_hostuuid:nextcloud
host_time:1
hostid:a88fcb34-0a0f-11ea-9f45-ac1f6b483830
hostid_strict_check:0
interfaces:vnet0:bridge0,vnet1:bridge1
ip4:new
ip4_addr:vnet0:bridge0|10.0.0.203/24
ip4_saddrsel:1
ip6:new
ip6_addr:none
ip6_saddrsel:1
ip_hostname:0
jail_zfs:0
jail_zfs_dataset:iocage/jails/nextcloud/data
jail_zfs_mountpoint:none
last_started:2020-02-03 17:09:23
localhost_ip:none
login_flags:-f root
mac_prefix:ac1f6b
maxproc:off
memorylocked:off
memoryuse:off
mount_devfs:1
mount_fdescfs:1
mount_linprocfs:0
mount_procfs:0
mountpoint:readonly
msgqqueued:off
msgqsize:off
nat:0
nat_backend:ipfw
nat_forwards:none
nat_interface:none
nat_prefix:172.16
nmsgq:off
notes:none
nsem:off
nsemop:off
nshm:off
nthr:off
openfiles:off
origin:readonly
owner:root
pcpu:off
plugin_name:none
plugin_repository:none
priority:99
pseudoterminals:off
quota:none
readbps:off
readiops:off
release:11.3-RELEASE-p5
reservation:none
resolver:/etc/resolv.conf
rlimits:off
rtsold:0
securelevel:2
shmsize:off
stacksize:off
state:down
stop_timeout:30
swapuse:off
sync_state:none
sync_target:none
sync_tgt_zpool:none
sysvmsg:new
sysvsem:new
sysvshm:new
template:0
type:jail
used:readonly
vmemoryuse:off
vnet:1
vnet0_mac:ac1f6bbab581 ac1f6bbab582
vnet1_mac:
vnet2_mac:none
vnet3_mac:none
vnet_default_interface:auto
vnet_interfaces:none
wallclock:off
writebps:off
writeiops:off
Best regards
Jürgen
