Brosif_My_Nif
- Jan 12, 2012
THE PROBLEM: I had a perfectly running volume for 3+ years that may be lost due to Sata drives being introduced to a brand new Supermicro SAS3 multipath, dual expander backplane environment. Any assistance that can be offered would be greatly appreciated.
OLD SERVER:
The volume was made up of 3 VDEV's (7-Disk, RAID-Z3).
These Sata drives have been running perfectly for the past 3+ years without any problems in the Norco 4224 chassis.
This Norco chassis was not handling cooling well, so I wanted to upgrade to a Supermicro Chassis. I also needed to add additional storage as I was nearly at 80% capacity of my existing volume.
UPGRADED SERVER:
This probably is not important, but I wired the HBA's to the front backplane and then to the rear backplane exactly as it is described in this screenshot below. When I only had the new HGST 12TB SAS drives in this box, it was showing 4 connections to each drive. 3 being Passive and 1 being active. It worked perfectly.
Then I proceeded to move my old pool of 21 sata disks into the new chassis. This is where the problems began.
I was doing this testing on a fresh installation of FreeNAS-11.1-U6. After placing the 21 sata disks into the new SAS3 dual-expander backplane of the Supermicro 847, and powering on the machine, I was met with a system alert. See image below.
I shut down the machine, removed the new 12TB HGST SAS disks that were still being tested and had no data on them, to make sure I was only dealing with my 21 old sata disks.
Upon reboot, the same error popped up again. So I immediately went to the "View Multipaths" tab and found some of the Sata drives were detecting multipath access and some were not. I did not expect the Sata drives to have ANY multipath access because I thought that only SAS drives had multipath capabilities. I was assuming that the old Sata drives would not even show up in the "View Multipaths" tab of the webgui. I thought it was strange that some of the drives were showing "Optimal" while some disks were showing as "Degraded".
MAJOR PROBLEM:
multipath/disk X: corrupt or invalid GPT detected.
multipath/disk X: GPT rejected -- may not be recoverable.
Multiple drives are showing GPT problems.
I then tried to import my existing volume that has been working great for 3+ years on my old hardware, but no volume is recognized.
If anyone can provide any assistance, it would truly mean the world to me.
Please see images below...
OLD SERVER:
- FreeNAS-11.1-U6
- Norco 4224 Chassis
- Supermicro X10SRH-CLN4F motherboard
- Xeon E5-1630v3
- 196 GB Samsung DDR4 ECC RAM
- LSI 9201-16i
- x7 - WD SE 4TB Sata HDD's (Raid Z-3) VDEV1
- x7 - WD RED 8TB Sata HDD's (Raid Z-3) VDEV2
- x7 - WD RED 8TB Sata HDD's (Raid Z-3) VDEV3
UPGRADED SERVER:
- FreeNAS-11.1-U6
- Xeon E5-1630v3
- All 21 Sata drives from old volume
- NEW: Supermicro SuperChassis 847BE2C-R1K28LPB (FRONT: 24-port SAS3 dual-expander backplane + BACK: 12-port SAS3 dual-expander backplane)
- NEW: VOLUME 2, x7 - HGST 12TB SAS HDD's (Raid Z-3)
- NEW: LSI 9305-24I
- NEW: LSI 9300-8I (Onboard the Supermicro X10SRH-CLN4F motherboard)
MAJOR PROBLEM:
Oct 19 21:22:40 freenas GEOM_MULTIPATH: disk1 created Oct 19 21:22:40 freenas GEOM_MULTIPATH: da0 added to disk1 Oct 19 21:22:40 freenas GEOM_MULTIPATH: da0 is now active path in disk1 Oct 19 21:22:40 freenas GEOM: multipath/disk1: corrupt or invalid GPT detected. Oct 19 21:22:40 freenas GEOM: multipath/disk1: GPT rejected -- may not be recoverable. Oct 19 21:22:40 freenas GEOM_MULTIPATH: da21 added to disk1 Oct 19 21:22:40 freenas GEOM_MULTIPATH: disk2 created Oct 19 21:22:40 freenas GEOM_MULTIPATH: da1 added to disk2 Oct 19 21:22:40 freenas GEOM_MULTIPATH: da1 is now active path in disk2 Oct 19 21:22:40 freenas GEOM: multipath/disk2: corrupt or invalid GPT detected. Oct 19 21:22:40 freenas GEOM: multipath/disk2: GPT rejected -- may not be recoverable. Oct 19 21:22:40 freenas GEOM_MULTIPATH: da22 added to disk2 Oct 19 21:22:40 freenas GEOM_MULTIPATH: disk3 created Oct 19 21:22:40 freenas GEOM_MULTIPATH: da2 added to disk3 Oct 19 21:22:40 freenas GEOM_MULTIPATH: da2 is now active path in disk3 Oct 19 21:22:40 freenas GEOM: multipath/disk3: corrupt or invalid GPT detected. Oct 19 21:22:40 freenas GEOM: multipath/disk3: GPT rejected -- may not be recoverable. Oct 19 21:22:40 freenas GEOM_MULTIPATH: da23 added to disk3 Oct 19 21:22:40 freenas GEOM_MULTIPATH: disk4 created Oct 19 21:22:40 freenas GEOM_MULTIPATH: da3 added to disk4 Oct 19 21:22:40 freenas GEOM_MULTIPATH: da3 is now active path in disk4 Oct 19 21:22:40 freenas GEOM: multipath/disk4: corrupt or invalid GPT detected. Oct 19 21:22:40 freenas GEOM: multipath/disk4: GPT rejected -- may not be recoverable. Oct 19 21:22:40 freenas GEOM_MULTIPATH: da24 added to disk4 Oct 19 21:22:41 freenas GEOM_MULTIPATH: disk5 created Oct 19 21:22:41 freenas GEOM_MULTIPATH: da4 added to disk5 Oct 19 21:22:41 freenas GEOM_MULTIPATH: da4 is now active path in disk5 Oct 19 21:22:41 freenas GEOM: multipath/disk5: corrupt or invalid GPT detected. Oct 19 21:22:41 freenas GEOM: multipath/disk5: GPT rejected -- may not be recoverable. Oct 19 21:22:41 freenas GEOM_MULTIPATH: da25 added to disk5 Oct 19 21:22:41 freenas GEOM_MULTIPATH: disk6 created Oct 19 21:22:41 freenas GEOM_MULTIPATH: da5 added to disk6 Oct 19 21:22:41 freenas GEOM_MULTIPATH: da5 is now active path in disk6 Oct 19 21:22:41 freenas GEOM: multipath/disk6: corrupt or invalid GPT detected. Oct 19 21:22:41 freenas GEOM: multipath/disk6: GPT rejected -- may not be recoverable. Oct 19 21:22:41 freenas GEOM_MULTIPATH: da26 added to disk6 Oct 19 21:22:41 freenas GEOM_MULTIPATH: disk7 created Oct 19 21:22:41 freenas GEOM_MULTIPATH: da6 added to disk7 Oct 19 21:22:41 freenas GEOM_MULTIPATH: da6 is now active path in disk7 Oct 19 21:22:41 freenas GEOM: multipath/disk7: corrupt or invalid GPT detected. Oct 19 21:22:41 freenas GEOM: multipath/disk7: GPT rejected -- may not be recoverable. Oct 19 21:22:41 freenas GEOM_MULTIPATH: da27 added to disk7 Oct 19 21:22:41 freenas GEOM_MULTIPATH: disk8 created Oct 19 21:22:41 freenas GEOM_MULTIPATH: da7 added to disk8 Oct 19 21:22:41 freenas GEOM_MULTIPATH: da7 is now active path in disk8 Oct 19 21:22:41 freenas GEOM: multipath/disk8: corrupt or invalid GPT detected. Oct 19 21:22:41 freenas GEOM: multipath/disk8: GPT rejected -- may not be recoverable. Oct 19 21:22:41 freenas GEOM_MULTIPATH: da28 added to disk8 Oct 19 21:22:41 freenas GEOM_MULTIPATH: disk9 created Oct 19 21:22:41 freenas GEOM_MULTIPATH: da8 added to disk9 Oct 19 21:22:41 freenas GEOM_MULTIPATH: da8 is now active path in disk9 Oct 19 21:22:41 freenas GEOM: multipath/disk9: corrupt or invalid GPT detected. Oct 19 21:22:41 freenas GEOM: multipath/disk9: GPT rejected -- may not be recoverable. Oct 19 21:22:41 freenas GEOM_MULTIPATH: da29 added to disk9 Oct 19 21:22:41 freenas GEOM_MULTIPATH: disk10 created Oct 19 21:22:41 freenas GEOM_MULTIPATH: da9 added to disk10 Oct 19 21:22:41 freenas GEOM_MULTIPATH: da9 is now active path in disk10 Oct 19 21:22:41 freenas GEOM: multipath/disk10: corrupt or invalid GPT detected. Oct 19 21:22:41 freenas GEOM: multipath/disk10: GPT rejected -- may not be recoverable. Oct 19 21:22:41 freenas GEOM_MULTIPATH: da30 added to disk10 Oct 19 21:22:41 freenas GEOM_MULTIPATH: disk11 created Oct 19 21:22:41 freenas GEOM_MULTIPATH: da10 added to disk11 Oct 19 21:22:41 freenas GEOM_MULTIPATH: da10 is now active path in disk11 Oct 19 21:22:41 freenas GEOM: multipath/disk11: corrupt or invalid GPT detected. Oct 19 21:22:41 freenas GEOM: multipath/disk11: GPT rejected -- may not be recoverable. Oct 19 21:22:41 freenas GEOM_MULTIPATH: da31 added to disk11 Oct 19 21:22:42 freenas GEOM_MULTIPATH: disk12 created Oct 19 21:22:42 freenas GEOM_MULTIPATH: da11 added to disk12 Oct 19 21:22:42 freenas GEOM_MULTIPATH: da11 is now active path in disk12 Oct 19 21:22:42 freenas GEOM: multipath/disk12: corrupt or invalid GPT detected. Oct 19 21:22:42 freenas GEOM: multipath/disk12: GPT rejected -- may not be recoverable. Oct 19 21:22:42 freenas GEOM_MULTIPATH: disk13 created Oct 19 21:22:42 freenas GEOM_MULTIPATH: da12 added to disk13 Oct 19 21:22:42 freenas GEOM_MULTIPATH: da12 is now active path in disk13 Oct 19 21:22:42 freenas GEOM: multipath/disk13: corrupt or invalid GPT detected. Oct 19 21:22:42 freenas GEOM: multipath/disk13: GPT rejected -- may not be recoverable. Oct 19 21:22:42 freenas GEOM_MULTIPATH: disk14 created Oct 19 21:22:42 freenas GEOM_MULTIPATH: da13 added to disk14 Oct 19 21:22:42 freenas GEOM_MULTIPATH: da13 is now active path in disk14 Oct 19 21:22:42 freenas GEOM: multipath/disk14: corrupt or invalid GPT detected. Oct 19 21:22:42 freenas GEOM: multipath/disk14: GPT rejected -- may not be recoverable. Oct 19 21:22:42 freenas GEOM_MULTIPATH: disk15 created Oct 19 21:22:42 freenas GEOM_MULTIPATH: da14 added to disk15 Oct 19 21:22:42 freenas GEOM_MULTIPATH: da14 is now active path in disk15 Oct 19 21:22:42 freenas GEOM: multipath/disk15: corrupt or invalid GPT detected. Oct 19 21:22:42 freenas GEOM: multipath/disk15: GPT rejected -- may not be recoverable. Oct 19 21:22:42 freenas GEOM_MULTIPATH: disk16 created Oct 19 21:22:42 freenas GEOM_MULTIPATH: da15 added to disk16 Oct 19 21:22:42 freenas GEOM_MULTIPATH: da15 is now active path in disk16 Oct 19 21:22:42 freenas GEOM: multipath/disk16: corrupt or invalid GPT detected. Oct 19 21:22:42 freenas GEOM: multipath/disk16: GPT rejected -- may not be recoverable. Oct 19 21:22:43 freenas GEOM_MULTIPATH: disk17 created Oct 19 21:22:43 freenas GEOM_MULTIPATH: da16 added to disk17 Oct 19 21:22:43 freenas GEOM_MULTIPATH: da16 is now active path in disk17 Oct 19 21:22:43 freenas GEOM: multipath/disk17: corrupt or invalid GPT detected. Oct 19 21:22:43 freenas GEOM: multipath/disk17: GPT rejected -- may not be recoverable. Oct 19 21:22:43 freenas GEOM_MULTIPATH: disk18 created Oct 19 21:22:43 freenas GEOM_MULTIPATH: da17 added to disk18 Oct 19 21:22:43 freenas GEOM_MULTIPATH: da17 is now active path in disk18 Oct 19 21:22:43 freenas GEOM: multipath/disk18: corrupt or invalid GPT detected. Oct 19 21:22:43 freenas GEOM: multipath/disk18: GPT rejected -- may not be recoverable. Oct 19 21:22:43 freenas GEOM_MULTIPATH: disk19 created Oct 19 21:22:43 freenas GEOM_MULTIPATH: da18 added to disk19 Oct 19 21:22:43 freenas GEOM_MULTIPATH: da18 is now active path in disk19 Oct 19 21:22:43 freenas GEOM: multipath/disk19: corrupt or invalid GPT detected. Oct 19 21:22:43 freenas GEOM: multipath/disk19: GPT rejected -- may not be recoverable. Oct 19 21:22:43 freenas GEOM_MULTIPATH: disk20 created Oct 19 21:22:43 freenas GEOM_MULTIPATH: da19 added to disk20 Oct 19 21:22:43 freenas GEOM_MULTIPATH: da19 is now active path in disk20 Oct 19 21:22:43 freenas GEOM: multipath/disk20: corrupt or invalid GPT detected. Oct 19 21:22:43 freenas GEOM: multipath/disk20: GPT rejected -- may not be recoverable. Oct 19 21:22:43 freenas GEOM_MULTIPATH: disk21 created Oct 19 21:22:43 freenas GEOM_MULTIPATH: da20 added to disk21 Oct 19 21:22:43 freenas GEOM_MULTIPATH: da20 is now active path in disk21 Oct 19 21:22:43 freenas GEOM: multipath/disk21: corrupt or invalid GPT detected. Oct 19 21:22:43 freenas GEOM: multipath/disk21: GPT rejected -- may not be recoverable.
