Hi all,
For some reason I get strange behaviour with a pool that I would like to use for backups.
I have decided to replace my raidz2 pool (old) with a striped mirror pool (new) and the replacement went just fine, except that:
Additional Info:
Anyone here who might have some answers?
I'll probably just plug the old pool back in... just to see if that fixes the Problem. Though if it does, I'll be even more clueless.
Edit: Importing the old pool on my laptop works just fine... even though it still shows as being two vdevs with 2 mirrored drives in it. I can't explain how that is possible, since I was 100% sure I had a raidz2 setup... but I guess I was wrong. Still does not explain why I am unable to import the pool within freenas.
- the old pool which lived inside my HP Microserver Gen8 is now connected via two USB docks
- the old pool - which worked just fine prior to me pulling the disks out - now shows as a striped mirror and is degraded, because disks can't be opened... how is that possible?:
zpool status:
Code:pool: tank1 id: 5794346787872140487 state: DEGRADED status: One or more devices are missing from the system. action: The pool can be imported despite missing or damaged devices. The fault tolerance of the pool may be compromised if imported. see: http://illumos.org/msg/ZFS-8000-2Q config: tank1 DEGRADED mirror-0 DEGRADED gptid/2512b179-1260-11e8-87cc-3464a99a6588 ONLINE 22011067663477126 UNAVAIL cannot open mirror-1 DEGRADED 1259817509696220100 UNAVAIL cannot open gptid/28687134-1260-11e8-87cc-3464a99a6588 ONLINE
- the old pool yields GPT errors in dmesg:
Code:da1 at umass-sim1 bus 1 scbus8 target 0 lun 0 da1: <WDC WD20 EFRX-68EUZN0 0> Fixed Direct Access SPC-4 SCSI device da1: Serial Number 1234567890DD da1: 40.000MB/s transfers da1: 1907729MB (3907029168 512 byte sectors) da1: quirks=0xa<NO_6_BYTE,4K> GEOM_MULTIPATH: disk2 created GEOM_MULTIPATH: da1 added to disk2 GEOM_MULTIPATH: da1 is now active path in disk2 da2 at umass-sim1 bus 1 scbus8 target 0 lun 1 da2: <WDC WD20 EFRX-68EUZN0 0> Fixed Direct Access SPC-4 SCSI device da2: Serial Number 1234567890DD da2: 40.000MB/s transfers da2: 1907729MB (3907029168 512 byte sectors) da2: quirks=0xa<NO_6_BYTE,4K> GEOM: multipath/disk2: corrupt or invalid GPT detected. GEOM: multipath/disk2: GPT rejected -- may not be recoverable. ugen1.2: <ASMT ASM1156-PM> at usbus1 umass2 on uhub2 umass2: <ASMT ASM1156-PM, class 0/0, rev 3.00/1.00, addr 1> on usbus1 umass2: SCSI over Bulk-Only; quirks = 0x0000 umass2:9:2: Attached to scbus9 da3 at umass-sim2 bus 2 scbus9 target 0 lun 0 da3: <ASMT ASM1156-PM 0> Fixed Direct Access SPC-4 SCSI device da3: Serial Number 00000000000000000000 da3: 400.000MB/s transfers da3: 1907729MB (3907029168 512 byte sectors) da3: quirks=0x2<NO_6_BYTE> GEOM_MULTIPATH: disk1 created GEOM_MULTIPATH: da3 added to disk1 GEOM_MULTIPATH: da3 is now active path in disk1 da4 at umass-sim2 bus 2 scbus9 target 0 lun 1 da4: <ASMT ASM1156-PM 0> Fixed Direct Access SPC-4 SCSI device da4: Serial Number 00000000000000000000 da4: 400.000MB/s transfers da4: 1907729MB (3907029168 512 byte sectors) da4: quirks=0x2<NO_6_BYTE> GEOM: multipath/disk1: corrupt or invalid GPT detected. GEOM: multipath/disk1: GPT rejected -- may not be recoverable.
- the new pool appears to work just fine (all data is accessible) but gpart shows it as CORRUPT:
Code:Name Status Components da0p1 OK da0 da0p2 OK da0 ada0p1 CORRUPT ada0 ada0p2 CORRUPT ada0 ada1p1 CORRUPT ada1 ada1p2 CORRUPT ada1 ada2p1 OK ada2 ada2p2 OK ada2 ada3p1 OK ada3 ada3p2 OK ada3 da2p1 OK da2 da2p2 OK da2 da4p1 OK da4 da4p2 OK da4
Additional Info:
- camcontrol devlist
This is strange, since ALL drives are WD REDs. No idea why da3/4 are shown as ASMT.
Code:<WDC WD20EFRX-68AX9N0 80.00A80> at scbus0 target 0 lun 0 (pass0,ada0) <WDC WD20EFRX-68AX9N0 80.00A80> at scbus1 target 0 lun 0 (pass1,ada1) <WDC WD20EFRX-68EUZN0 82.00A82> at scbus2 target 0 lun 0 (pass2,ada2) <WDC WD20EFRX-68EUZN0 82.00A82> at scbus3 target 0 lun 0 (pass3,ada3) <SanDisk Ultra 1.00> at scbus7 target 0 lun 0 (pass4,da0) <WDC WD20 EFRX-68EUZN0 0> at scbus8 target 0 lun 0 (da1,pass5) <WDC WD20 EFRX-68EUZN0 0> at scbus8 target 0 lun 1 (da2,pass6) <ASMT ASM1156-PM 0> at scbus9 target 0 lun 0 (da3,pass7) <ASMT ASM1156-PM 0> at scbus9 target 0 lun 1 (da4,pass8)
