I am just starting out with FreeNAS at home and it has been fairly smooth getting up and running.
I have installed the SabNZB, Transmission, SickBeard & CouchPotato plugins and have created a shared 'Completed' storage directory on my Jails drive (see below) which is shared via SMB to my Windows machines.
I now have a confusion on the best way to go though. I wish to share my Movie and TV library so CouchPotato and SickBeard can manage. My media is on a zvol current shared out as a block device to my Windows Server.
I can change the media drive to a datastore and not go via the Windows server if that makes more sense bit if I go that route then now is the time to do it before I populate the drives.
Is there a way to share the media share as zvol easily with the jails or would it be better to convert to a datastore which I can then just use with 'add storage' to the jails or is there another option which may work better ?.
Setup;
Server.
SabNZB (ip: 100)
CouchPotato (ip:101): Talks to SabNZB via API.
SickBeard (ip: 102): Talks to SabNZB via API.
Transmission (ip: 103)
Any ideas, guides or suggestions gratefully received.
Setup;
Server.
- Dual L5640 (6c/12t) cpus.
- Supermicro server board.
- 48GB RDiMM ECC ram.
- 2x LSI 9211-8i HBAs.
- Intel EXPX9502AFXSR 10Gbit network (dual port).
- Boot: Seagate 160GB (needs changing).
- Jails (Datastore): HGST 2TB 7.2k Ultrastar drives.
- Storage (Raid 10 --> zvol - iSCSI): 8x HGST 2TB 7.2k Ultrastar drives.
- Unused: 2x Intel 520 120GB SSDs.
- \\mediaServer\TV
- \\mediaServer\Movies
SabNZB (ip: 100)
- Data: /mnt/completed (shared SMB)
- Data: /mnt/nzbIn (shared SMB)
- No view of media library currently.
- Data: /mnt/completed/torrent (shared SMB)
